![]() | Home > Technical > Bluesea Fuse Box |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
4.3mm should do.
Positive screws are 4mm. hth Brendan |
| SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527
Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
| mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645
Let me know if you need some we have red, blue and yellow. You will need 1mm bigger for the positive (and negative bus if you have one)
If you are running a lot of heavy stuff use 16mm2 on the supply cables which you will need copper tube terminals for. |
