Home > Technical > Rear Brake Problem - MOT Failure
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
My Defender failed it's MOT today. Rear brake forces were only 70 and 80kg vs 363 and 365kg on the front.
It's a 2000 TD5 90, no ABS.
Had new disks and pads only 12000 miles ago so I'm guessing it's something else. Servo seems to be working so I guess the vacuum pump is doing its job.
As it's both sides it must be something common to the both. Bias valve maybe?
Before I start ripping the thing apart what should I look for? Anyone had a similar problem?
Post #167685 11th Sep 2012 7:00pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Oil on the disc? I recently had a hub seal leaking leading to a rather alarming pull to the left under braking.
Post #167691 11th Sep 2012 7:24pm
me@td5.org
I'l take a look and give them a good coat of brake cleaner
Post #167696 11th Sep 2012 7:36pm
AndyS
Bleed the lines as well, if nothing else it's a good reason to get up close and personal with the system.
Post #167700 11th Sep 2012 7:42pm
Pistons sticking in the calipers?
Post #167701 11th Sep 2012 7:44pm
