![]() | Home > Technical > Early Series Type Doors on Defender |
not sure on the space issue as they fill the same hole in the same way!
the anti burst things to stop the door opening whe you hit a bump http://www.paddockspares.com/2006abr-door-...icles.html its the tops that are expensive as you'd be best to get the ali double slders. |
Tig up - You get more elbow room as there is no door card / wind down window
I used the rear door lock as the drivers side one on my Trayback |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
I'm happy to pay for some good door tops as the comparative cost to new wind up window doors is huge.
I am weighing up whether to go for Ashtree Galv bottoms with Rock Mountain tops or if I should get the whole lot from Rocky Mountain. |
I have a pair of Rocky Mountain tops that I picked up on Ebay - very please with the quality - I haven't seen the Ashtree ones I'm afraid so can't comment - HTH
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218 ![]() ![]() ![]() |
The drivers side lock unit isn't the same as the rear end safari door... I've just fitted a pair to the project90 i've got (using military split doors)
Although with some grinding/cutting, I suspect that the rear catch (not the lock that's on the door, but the cast iron bit that bolts to the bodywork frame) could be suitably bodgified to work on the front door. Although for what they cost even new, I'd be inclined to use the proper one seeing as that is what stops you from falling out. |
That is useful to know. I have no problem which buying the right thing. I just want to make sure I can set them all up with the same key!
I'm sorry, I thought you were talking about the 'keep', the bit that stays on the vehicle, not on the door - they are the same as the rear door and people use those because drivers side ones seem scarce for some reason
They're not the same. they are interchangeable, like I said, with some bodgification., but not the same... the rear one has the rubber buffer thing on it to stop the door from vibrating. |
Am I at least right that they are used because you can't get the drivers side originals
I hadn't realised that the strikers were different either! Just as well I didn't buy a pair of X-Trousers at the weekend!
Are the hole centres the same? |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1389 ![]() ![]() ![]() |
Phil , our kid has just done it with his USW, if you have a look on my FB page, i've commented on it so you should see what it looks like... Putting Dreams on Drives at JLR Solihull..
Cheers Ada, is there anyone in your Family that doesn't have a Landy? |
errrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr.....NO ! Putting Dreams on Drives at JLR Solihull..
