Home > Maintenance & Modifications > Headlamp Rims
derek
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Headlamp Rims
Just fitted a pair of stainless steel rims from mobilecentre went on easy perfect fit mine were nearly rusted through on my 07 puma its a shame you can hardly see them.
Post #167300 10th Sep 2012 10:46am
T1G UP
but you can see the rust running down on the old ones!
Post #167301 10th Sep 2012 10:54am
derek
Ha true I think the lamps were about to fall out
D
Post #167317 10th Sep 2012 12:07pm
I did this too about 9 months ago. Well worth doing. Begs the question of why LR don't use them at the factory after all if people have them replaced all the time it'll cost more. False economy Confused ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #167327 10th Sep 2012 12:24pm
K9F
Along with the rest of the items that need sorting that is.......
K9F wrote:
The 90 has two vertical welds below the windows on the side (the 110 doesn't posess these welds) one of which wasn't formed correctly and subsequently the paint cracked and there was evidence of rust bubbling. Reformation of the weld!
On the nearside corner of the windscreen between the rubber seal and the 'non functional' hinge blocks there was also evidence of paint lifting and a small track of bubbling. Windscreen out job!!!
On the rear there are two small shaped panels that are riveted to the bodywork either side of the vehicle above numberplate height. There was very minor corrosion evidence due to the original paintwork not adhering to the sharp edges. Smooth off the sharp edges slightly and respray.
With everything else that has caused me grief with regards to poor paint finish having been either swapped out for superior products or reworked to prevent reoccurence such as hinge blocks, headlight retaining rings, front bumper, sidesteps, window latches I am hoping now to have a period without rust cultivation, paint flaking and the depressive feeling when it is discovered for some time to come.
Still wouldn't do without it. Think it's a classic case of 'warts 'n' all!' Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #167329 10th Sep 2012 12:30pm
yorky
England 2007 Defender 90 Puma 2.4 SW Java Black
Ye, just fitted my SS headlamp rims also from Mobilcentre. My 07 original fit ones were a disgrace, the new ones are excellent and fitted straight on. If you put your little pinky in the gap you can see the reflection - its the only way to tell you've got SS ones. The one who must be obeyed didn't seem too impressed with this demonstration!! Rolling with laughter 90 XS
Volvo V70
Post #169234 19th Sep 2012 10:57am
derek
I know what you mean, just the thought of something so rusty holding your lights in was enough for me
Post #169240 19th Sep 2012 11:04am
yorky
That's another thing ticked off the list, but I just keep adding new items to my wish list! Thinking of the LED side and indicator lights from Mobilcentre next! 90 XS
Volvo V70
Post #169242 19th Sep 2012 11:09am
