Home > Maintenance & Modifications > starting options
how to start my car
stock battery
87%
 87%  [7]
single monster lead acid battery
12%
 12%  [1]
twin batteries and 24 volt starter
0%
 0%  [0]
Total Votes: 8
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
starting options
Ho all.
My optima 4.2 is about dead. So I'm looking at alternate options. First is a normal lead acid battery from halfords at 600cca or stock spec. Second is the biggest lead battery I can find that fits at 900cca plus or third go for a 2 batteries and 24volt starter like land cruisers. What would you do and why?
Cheers. Rhubarb and custard let fly with their secret weapon.
Post #166988 8th Sep 2012 9:13am
K9F
I had a battery from Halfords and they used to give a four year no quibble guarantee. (Not sure if they still do!) But I ended up swapping it out at the three-year plus stage and had no problems whatsoever.
Dependant on guarantee I would 'lean' towards Halfords personally. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #166989 8th Sep 2012 9:16am
T1G UP
what are you starting... a lorry!
get a Numax CXV24MF http://www.tayna.co.uk/Numax-Leisure-Batteries-S284-1.html
You can even fit 2 of these in a defnder battery box.
they have Cold Cranking Amps of 1000 Thumbs Up
I have 2 of these going in my 110. they have twin connectors, so big one for the car, smaller ones for extras.
Post #166990 8th Sep 2012 9:18am
lambert.the.farmer
I thought leisure batteries weren't designed for starting cars? Rhubarb and custard let fly with their secret weapon.
Post #166993 8th Sep 2012 9:26am
T1G UP
read the blurb......they do both...very well
http://www.tayna.co.uk/Numax-CXV24MF-P3126.html
Post #166994 8th Sep 2012 9:28am
noworries4x4
Just go for the standard Land Rover one warrenty is bulet proof only about £15 dearer than the Halfords one.
Does what it says on the tin If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #166996 8th Sep 2012 9:35am
spudfan
Ireland
Halfords three year guarantee on the lead acid batteries and four year guarantee on the slightly dearer calcium battery. No quibble and if you have bother you can go to ANY branch with your receipt and get an exchange. Have used them and would recommend them.
The current Land Rover Varta is a good battery and made in Germany. Halfords batteries seem to be made in Germany too judging by the paperwork stuck to the side of them. If I could not get a Varta I'd get a similar spec from Halfords. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #167023 8th Sep 2012 4:55pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
Another option could be the following:
D44 battery tray, 2x PC1500DT batteries - CCA of 880 each, 2250A for 5 secs. Keep the systems as 12V, include some form of controller/diodes/relays and then the second battery can be used for auxillary only to power anything else you have and keep the main battery fresh for starting.
I use a Genesyz controller - press a button for start assist; press again for winch assist.
Started first time (actually without the start assist) at -40C in Sweden last winter
Post #167032 8th Sep 2012 6:24pm
wslr
Genuine Part battery is fine.
Post #167034 8th Sep 2012 6:42pm
lambert.the.farmer
Having a halfords trade card does make their 3 year one quite reasonable on price only 10quid less than the numax one above but with half the oomph. Rhubarb and custard let fly with their secret weapon.
Post #167037 8th Sep 2012 6:47pm
T1G UP
the choice....is yours!
i've chosen the numax as i get 20% off that price...VAT Whistle so that makes them half of an odyssey.
Post #167039 8th Sep 2012 7:20pm
lambert.the.farmer
I used to be indecisive but now I'm not so sure.
Took the plunge and got a Bosch type 75 in silver 5year guarantee spec 68 ah and 600cca. Supposedly it will stand the short burst frequent start driving that the car is subjected to better than most. Besides 5 years to take it back if it is no good has to have some merit. Also as it's slightly less bulky than both stock and the optima I gain a bit more room for junk in the battery compartment. Happy days. Rhubarb and custard let fly with their secret weapon.
Post #167199 9th Sep 2012 8:48pm
dgardel
Italy
Re: starting options
Ho all.
Cheers.
Land Cruiser (the 95 and 120 HD specs.) have two batteries IN PARALLEL, always 12V at all....
With the 150A rated Defender Puma generator is quite "normal" to install 2 batteries in parallel..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #167223 9th Sep 2012 10:17pm
