Home > Maintenance & Modifications > 2 inch lowering springs!
BigRuss
The house I've just moved to has a slightly lower garage that where I moved from so need to lower the back of the defender to make it sit level with the front.
Has anyone got any experience with these?
The garage isnt mine so no I can't make it fit.
I'm not worried about the effects of the offroad ability as this will be a short term measure so the wife can get the defender out of the garage on her own.
Cheers Russell
2011MY 110 XS USW Black
Post #166494 5th Sep 2012 12:55pm
farmer giles
hi russ,
i remember someone fro switzerland doing this for the same reasons and getting specially made springs, he later reverted back to normal spring. i will try a search Thumbs Up
Post #166498 5th Sep 2012 1:01pm
farmer giles
http://www.defender2.net/forum/topic7382.html?highlight=lowering
it turns out the bloke from switzerland was BPman, sorry Embarassed
hope this helps
Post #166501 5th Sep 2012 1:04pm
MartinK
I concated "szracer" off the forum on a similar subject.
He got his from Extreme 4x4, and he was happy with the result, the rear-end looking less "jacked-up" and a slightly better ride quality. To improve the softer springs, he also installed a "beefed up" anti-roll bar, and improved the handling...
I don't want to p@ss on his fire, but hopefully he'll add to the thread...
I'm considering the same (with Koni shocks), but may wait till my warranty expires (rumours are my local Dealer has been finding any reason possible to reject warranty claims Mad ) Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #166506 5th Sep 2012 1:31pm
I had a set of -2" made by extreme4x4 - standard "boing", TBH - I'd look at -1"s - that would probably do you.
It sounds odd but I did get a little vibration from the front prop with the lowered springs, this could easily fixed with a DC front prop (about £250 ish) or may not be necessary with -1"s
I sold the springs to Alive when I returned to the UK - Gary may well still have them ... worth a PM
Looking at the truck with -2"s - it levels the roofline
Post #166516 5th Sep 2012 2:07pm
Killer90
Site Sponsor
i have them from extreme on my 90 £50 a spring i think they retail for Thumbs Up but i heard they cant get hold of them for a while now as the guy who made them or sold them has left the job Rolling Eyes CSK Automotive
www.cskautomotive.co.uk
Post #166542 5th Sep 2012 4:59pm
Killer90
Site Sponsor
Comparison Thumbs Up CSK Automotive
Post #166545 5th Sep 2012 5:02pm
leeds
Might be worth considering tyre sizes. Going from a 33" OD tyre to a 29" OD tyre would achieve the same effect.
Or 1" lowered springs plus tyres 2" smaller in OD
Brendan
Post #166566 5th Sep 2012 6:40pm
Glynparry25
Post #166568 5th Sep 2012 6:55pm
markb110
Stupid question but will a couple of bags of cement just bring it down enough
I only say as i remember once i took all the gear and spare wheel out of the back of my old 110 i had the opposite issue and caught the door when driving out as i had removed a little too much weight Shocked
Good luck Russ
Mark
Post #166570 5th Sep 2012 7:21pm
For a temporary solution, changing the springs has surely got to be easier and cheaper than swapping tyres? Plus there would also be issues around gearing and the speedo reading. Darren
Post #166599 5th Sep 2012 9:09pm
davew
You're a bit limited in spring choices when it comes to 110 rears BUT you'll probably find there's an off the shelf spring that will do the job. +1, +2 etc... are all just a marketing term anyway and completely meaningless unless you know what sprung weight you'll be carrying.
If you know what the springs you currently have fitted are and are happy they're not sagging, you can calculate the sprung weight for each corner and, from that, establish the actual ride height you will get from the available springs.
Measure the height of the existing spring with the vehicle sat level, if you let me know the details (current height, spring type/markings, desired height) I have a spreadsheet that I use that has most of the common OEM and after market springs in it.
The real problem you normally have is coping with the range of weights that a CSW might be expected to carry, which is why they normally sit a bit high at the back unladen. A shorter spring that lowers the ride height when unladen will have to be stiffer to cope when it's laden without sitting it on the bump stops. http://www.yorkshireoffroadclub.net/
Post #166616 5th Sep 2012 9:34pm
T1G UP
air ride Thumbs Up
Post #166628 5th Sep 2012 10:14pm
markb110
Russ
I have just remembered that i have a set of rear springs in the garage that i had (when i had my 110) swapped for a set of rear TD5 springs to lift up the back end at the time.
Too late now to measure them so will do tomorrow when i get home.
I cant find any information of the free lengths of the current Puma springs so wont be able to compare - your not that far from me so happy pass them on to you if the lengths suit you.
Will catch up tomorrow evening
Mark
Post #166636 5th Sep 2012 10:30pm
keith
Hi when i moved house my garage door was 6 foot , my 110 and hanibal roofrack was 7 and a half feet , so i took the lintel out and raised the garage door hole to 8 feet and put on a new roller door. Job done .
Post #166637 5th Sep 2012 10:42pm
