Home > Maintenance & Modifications > EGT & boost pressure gauges
df1
Anyone fitted an exhaust gas temperature and boost pressure gauge combination to a td5 defender ?
I see IRB did a kit , anyone fit one ?
Post #164592 26th Aug 2012 8:49pm
3 Lions
Australia 2006 Defender 110 Td5 SW Chawton White
Is it the one at the bottom of the page here: http://www.mudstuff.co.uk/MUD_pod.shtml (Pete)
This is the one I was after for a long time. I eventually tracked it down to IRB being a distributer in the UK, they were pretty unhelpful, not knowing when they would get them in. I never heard from them again.
Eventually I found the manufacurer in the US. They are:http://www.mcnallyelectronics.com/digital_boost_gauges.htm
I hope this is of some help. I have a late 2006 TD5 110 Defender, which is chipped, that is why I ended up buying one of these, I thought they looked really good and I wanted to keep an eye on my EGT temps.
That was about 8 months ago, It is still sitting on a shelf in my garage, I really must get around to fitting it!! Laughing
Regards,
Col Wink
Post #165951 2nd Sep 2012 5:08pm
bob neville
I have a VDO turbo boost gauge waiting to go into my TD5.
Useless instructions and a pain to find the right connectors to plumb into the gauge.
The engine end is going to be plumbed into an Allard EGR removal tube that is going to replace the Alive one fitted. The Allard has a take off for the boost gauge already fitted Thumbs Up
2013 Defender 90 CSW - sold
Post #165966 2nd Sep 2012 5:49pm
wslr
Bob. I may be wrong, but I think you can just plumb the boost gauge into the TD5's rubber pipe going between the turbocharger actuator and the inlet pipework. We've only done one and it was a while ago. I think the kit came with a plastic T pipe but we ended up changing it for a metal one.
Post #166026 2nd Sep 2012 8:08pm
bob neville
You certainly can Thumbs Up
However, the VDO kit is useless, it does not include t's etc and has the wrong diameter tube supplied, my advice to anybody would be buy the gauge and source your own fittings.
Somebody gave me the Allard pipe and it has a plumbed in fitting with a barbed take off that will take the 6mm pipe needed to connect to the gauge.
Trying to get info on plumbing one in is like trying to get blood from a stone, especially as some of the gauges have NPT fittings and some have metric Shocked
Post #166034 2nd Sep 2012 8:24pm
wslr
Ah. Sounds like a pain. Big Cry
Post #166038 2nd Sep 2012 9:14pm
df1
Mcnallys seem to be the job alright.
They seem to do a kit with thermocouple, gauge and pressure sensor.
Might give one of the a try.
Thanks for the help.
Post #166060 2nd Sep 2012 10:18pm
barjout
Canada 1996 Defender 110 300 Tdi SW Alpine White
I installed the kit from Mcnally electronics and it does a perfect job. Easy to install with good instructions.
By barjout at 2012-09-02[/img]
Post #166066 2nd Sep 2012 11:04pm
3 Lions
Looks good, I have a mudpod on my Defender dashboard (with nothing in it at the moment) I have the same Mcnally gauge and switches like you have in your photo to go in......
Just need to pull my finger out and get them insatlled now Rolling Eyes
Col. 1979 Series 3 109 FFR (ex Aust Army.)
2006 Defender TD5 110.
2012 Trackabout CT.
Post #166097 3rd Sep 2012 9:33am
Glynparry25
Question..........
What boost does the TDCi use?......If anyone knows,
Glyn Dog Sheep
Post #166130 3rd Sep 2012 2:59pm
Naks
You can also go for the Madman unit, it measures EGT, Oil Pressure, Oil Temp, Battery levels, Coolant Temp, etc.
You can buy it online here: http://www.landyonlineretail.co.za/shop/sh...gory_id=25 --
Post #166131 3rd Sep 2012 3:22pm
Ooooh both of those look nice. Bow down Bow down
Post #166148 3rd Sep 2012 5:21pm
df1
The madman kit for the td5 doesn't appear to do boost pressure ?
As far as I can figure out anyway.
Madman looks very good value though.
Post #166171 3rd Sep 2012 7:21pm
davew
From what I can see the display/control unit is capable of working with a selection of sender units and you can mix and match. It looks like you can have a pressure input which can either show oil pressure, fuel pressure or boost depending on what you connect it to.
The TD5 kit looks to come as standard with oil pressure but if you wanted to change that for boost pressure I can't see why not.
It's a shame it doesn't support 2 pressure inputs but I suppose an additional oil pressure gauge is cheap enough to add if you have room. http://www.yorkshireoffroadclub.net/
Post #166195 3rd Sep 2012 8:37pm
paulcnn
Malta 1994 Defender 90 Td5 HT Barolo Black
Kit Link
Hi would it be possible to send me the link of this kit as I couldnt find it thanks, and if possible can you upload the pictures again because they have a broken link
Post #869353 24th Nov 2020 3:18pm
