![]() | Home > Maintenance & Modifications > Front seats in the rear of Defender 130? |
drive4change Member Since: 15 Aug 2012 Location: Somerset Posts: 193 ![]() ![]() ![]() |
Hi All,
Im sure i have seen people do this before. Does anyone know what modification is required to fit front seats in place of the rear 60/40 bench seat normally found in the defender 130? Pictures would be great if anyone has any?? Thanks Steve |
AlpenAndes Member Since: 20 May 2011 Location: Currently Chile Posts: 128 ![]() ![]() ![]() |
There are some consoles from a german supplier, http://www.wmparts.de/parts.php?akt_uk_id=16, but I do not know if they would fit a 130.
BR Oskar |
I know from ploughing through some forums a few years back that people have done it. Just trying to find out what the best way is. I guess there should really be an extended subframe for the seat to sit on as the raised area in the back of the 130 is not long enough to support the front of the seats. Also, i think the seats would probably be too low anyway.
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 ![]() ![]() ![]() |
You might get some ideas from this Foley add
http://www.ebay.co.uk/itm/1993-LAND-ROVER-...519fa3cee2 |
Looks like they have built a frame for each seat.
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 ![]() |
I've just emailed WM Parts in Germany for price for delivery to UK. Thank you AlpenAndes for the Link.
Welcome, I asked them as well, they said with a slight mod of the frame they do for a few Euros it also fits the 130. Lets see what they tell you.
BR Oskar |
That does look like a good system, and with lockable drawers underneath too. Just over £300. Plus getting it to the UK.
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Question............. Group buy? I would also be interested.
See what deal they need for discounts etc. GLyn ![]() ![]() |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 ![]() ![]() |
I had this made from plans posted on LR4x4, its intended for a 110 station wagon but it maybe a good starting point?
Just beware it restricts head room quite a bit! http://www.defender2.net/forum/post145322.html#145322 |
Headroom is def the problem isn't it
It made it impossible in the 110, I still havent found a solution I'm happy with for it
Jeremy,
Have you tried just making the mounts lower? I noticed that thee bracket you have made sits twice as high as the ones on the WM website? Glyn ![]() ![]() |
No, but I think that would work. If anything the one I had made is over engineered so to cut it down it would almost be easier to start again.
I dont have the time (or skills!) to have a go but if someone here does they're welcome to more accurate photos/ dimensions of my effort |
