![]() | Home > Technical > Steering wheel centering. |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 ![]() ![]() ![]() |
The steering wheel on my new (2008) 90 seems to be off center which I notice on a dead straight road.
I imagine the wheel just needs coming off and moving round one spline or so. Is this a straightforward unbolt, re-bolt or is there any more to it? How does the front part come off to reveal the bolt? Just yank? Advice before I get the socket set out would be appreciated. |
The centre pad just pulls off
The wheel will either be easy to get off or a right pig ! Undo the nut in the centre but DO NOT take it right off - the reason is if the wheel suddenly lets go when trying to pull it off it will certainly smack you in the face ![]() If the wheel wont budge you will need to make / obtain a tool - there is a thread on here that shows you if you search |
I must admit I thought it strange the wheel could be wrong. Perhaps I'll just mention it at the next service rather than mess around.
Thanks for the advice chaps. |
Blackwolf is absolutely right although I presumed you'd already checked the steering alignment and come to the conclusion that it was the wheel.
I've seen Thuds 90 and it is the 'bulbous pad' version with the threaded holes |
Sadly I wouldn't know how the check the steering alignment.
Carry out blackwolf's instructions or get a 'reputable' tyre place to check for you
Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756 ![]() ![]() |
If it is only out by a little bit then shortening or lengthening the drag ling by half a turn or so will correct it. Much easier than removing the wheel.
This is the drag link right?
I assume I loosen the clamps and turn it a quarter one way or another then clamp up again. It won't have a negative effect on the steering? Camber, toe in/out etc? ![]() Alright, in for a penny... *goes for tool box* Last edited by Thud on 17th Aug 2012 12:24pm. Edited 1 time in total |
Loosen clamps either end and rotate the bar. It won't affect the geometry in any way. If you have to turn it a lot to get the wheel straight then you must check that the wheels still stop on the steering stops before the steering box runs out of travel else you will damage the box.
Remember each spline of the steering wheel is about 7 degrees (assume you have a 48 spline column). So if the wheel is out by more than 3.5 degrees then it might be worth moving it one spline and then using the drag link method to fine tune it. |
Tried first with the wheel. Too much. So put the wheel back and tuned it in as directed.
Lovely and centered now. Thanks for the help! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18030 ![]() ![]() ![]() |
You're welcome!
Are you sure it wasn't camber effect that was making the steering wheel appear off centre? My 90 has the steering wheel just the L off centre on A and B roads. Centre on motorways and the exact opposite when driving on the continent. Just to the R off centre on non-autoroutes and central on the autoroute. Dead central when driving and braking on a former runway near us that is used by our model R C club.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
No. I've tested the theory on all sorts of roads including long motorway stretches. Made sure tyre pressures are correct ect.
Seems okay now and one more problem I can now solve if I ever need to. |
