![]() | Home > Maintenance & Modifications > Can I see your NAS step: Hudds/Bfd with spare on back door |
| JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758
Just a thought, HCPU tow bars have a spacer to clear the overhanging rear body. These towbars fit a staion wagon and move the ball further out.
I'm not near my HCPU for a while to measure but it may be an easier/ cheaper option than the NAS step |
| markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2701
Hi
The Thule version of that rack has the optional rear hoop angled to clear the spare wheel. I have not found out yet if that means that the tow ball can be mounted to the rear cross member or you need a drop plate to lower it a bit See attached from the Thule website Good luck Mark |
| mrandmrsh Member Since: 31 May 2010 Location: Huddersfield Posts: 692
Cheers all - Jeremy - cracking spot that and a great idea as it's all type approved and good to go. Prices are eyewatering though (just short of £200) but might have a look around for a second hand one.
Click image to enlarge Click image to enlarge I notice there seem to be two different types here. One a bolt on to the standard 110 drop plate and the other a revised drop plate with extension bit on it. C 2015 110 USW XS in Santorini with premium contrast leather seats in tan/black, black headlining and with Dual Finish alloys (in the garage, now on Wolf rims with Goodyear MT/Rs) 2012 '62' 2.2 X-Tech 110 USW now gone ... 1984 90 soft top with full roll cage, 200 tdi engine etc now sold 2012 USW XS 2.2 "FUU" now gone.... |
| ben_j85jty Member Since: 03 Sep 2008 Location: Bicester, Oxfordshire Posts: 491
2 on ebay at the moment, about £50 or so. 2002 Defender 110 DC
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
Looking at that extension part on it's own looks a bit like the spacer that was on my Disco2 which enabled the tow ball to be stepped further away from the back. Just a thought, you might get a more reasonably priced one from a Disco.
what are you searching for? I dunno what to call it. C 2015 110 USW XS in Santorini with premium contrast leather seats in tan/black, black headlining and with Dual Finish alloys (in the garage, now on Wolf rims with Goodyear MT/Rs) 2012 '62' 2.2 X-Tech 110 USW now gone ... 1984 90 soft top with full roll cage, 200 tdi engine etc now sold 2012 USW XS 2.2 "FUU" now gone.... Last edited by mrandmrsh on 14th Aug 2012 3:52pm. Edited 1 time in total |
| TR51 Member Since: 17 Apr 2012 Location: Dorset UK Posts: 333
There you go:
http://www.ebay.co.uk/itm/Genuine-Landrove..._500wt_922 Searched 'Land Rover 130 tow bar' Ben may be able to give another search term as I only found one... P.S. Martin: Hope it's ok here, rather than in the Ebay section |
| sewin elwy Member Since: 08 Aug 2012 Location: Snowdonia Posts: 39
Hi, yeh, been there. Changed back to the defender after a disc 3 on which i used a thule rack that is simmilar to yours. Worked out I'd have problems from the start so put a NAS step on straight away, still wasn't quite enough room. The thule rack tips down using a lever and you lift it back into place, but the support bar at the back fouled on the spare. I'd worked out that If I put an adjustable drop plate on the NAS step that it would fit alright as I didn't need much room but in the end I just modified the bike rack by repositioning the locking pins and holes so that the rack now sits about level rather than at a slight angle. Hope it helps and it can be done! Martin. |
