Home > Maintenance & Modifications > Full of cr*p!
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
Full of cr*p!
Where the heater duct funnels down inside the wing the 'neck' bit of full of wet crud.
Surely the duct being on top is going to get the full hit of rain plus a mix of dust.
How best can I clean the crap out. Is the hole a vent hole so I can ram it with some wire or is this hole a route to the heater fan and I should be a bit careful?
Should I fit a downward style snow duct?
Post #160451 7th Aug 2012 9:25am
farmer giles
hi thud,
at the bottom of the duct there should be a black rubber "teat" to let the water drain out, sometimes is sticks closed.
the kbx cover might also be a consideration?
Post #160455 7th Aug 2012 10:18am
Or a snow guard:
Cleaning the teat on the heater duct is one of those little 'service' jobs that gets forgotten - usually until water appears in the passenger footwell. If checked periodically, it shouldn't really be a problem.
The teat can be found be running your hand down the side of the heater duct in the engine bay until you get to the bottom.
Having just read back the above, I realise that this whole subject is a double entendre minefield Laughing Darren
Post #160460 7th Aug 2012 10:37am
Thud
Teat pulled out and washed. Another job done!
Good work chaps!
Post #160461 7th Aug 2012 10:39am
ZeDefender
The LR dealer here just pulled the teat off and threw it away without even asking me Shocked Tell someone you love them today because life is short.
Post #160465 7th Aug 2012 11:16am
ericvv
Had the same problem once, but then after cleaning also installed a Entreq snow cover, and no further issues sofar.
Speaking of "teat", after reading the recent posts about airco condensation water in footwells due to blocked drainage teat which apparently located somewhere over and above the gearbox, I have tried carefully to locate that from underneath the car, but while finding all kinds of things there (without being able to see them) I could not find this teat sofar. I have no water issue, but just wanted to take a preventive look at it. If anyone has a very clear picture it might help to locate it You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #160469 7th Aug 2012 11:44am
farmer giles
here you go eric.
must admit that i don't know if the td5 one above is the same as the puma; but it is the small rubber thing with a tapering chisel end (it is infront of the single red wire in the picture).
Post #160480 7th Aug 2012 12:26pm
The Td5 one is very similar. looks like the exact same teat, just ina slightly different place (pop the bonnet, look at the air intake pan thing, it's on the front corner)
Post #160497 7th Aug 2012 1:44pm
ericvv
So to be sure, with the Puma the teat to release the condense water of the airco is the one on the front corner of the air intake pan,the one which is very easy to reach by hand? You never actually own a Defender. You merely look after it for the next generation.
Post #160553 7th Aug 2012 4:54pm
No, I think some confusion has crept in. Farmer Giles' photo and Jims' comment relate to the air intake drain under the front wing. The aircon drain is underneath near to the gearbox. I have seen pictures of the latter posted before so a search might find them. Darren
Post #160557 7th Aug 2012 5:21pm
ericvv
OK, that makes sense. Yes, I saw that photo too with a red circle around the teat, but still could not find it when feeling around the gearbox area You never actually own a Defender. You merely look after it for the next generation.
Post #160562 7th Aug 2012 5:24pm
