![]() | Home > Technical > Main/Aux battery lighting Question |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 ![]() ![]() ![]() |
I would say the wire should come from the switch to activate the relay when you select full beam. Russell
2011MY 110 XS USW Black |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218 ![]() ![]() ![]() |
I would use a 3 way switch (on/off/on) to control the LED bar relay
One of the "on"s will be fed from the aux 12v battery (as well as the main feed for the LED lampbar) The other "on" just comes directly from the main beam feed.... doesn't really matter where you take the feed from, either the headlights themselves or the back of the switch... it's all the same feed. The LED bar 3 way switch will isolate the AUX and MAIN battery feeds, as the main beam feed (when switched to "main" will only energise the coil then go to earth) OR the AUx battery will energise the relay... the two will never be connected, thus: ![]() Click image to enlarge The light blue wires is the "feed" from the cars main beam circuit onto your 3 way switch for the LED bar and don't forget a fuse!!!!!! |
thanks Guys, DJ - I like that soultion, simple and no more relays etc - I'll go find a nice switch
Carling do a 3 way on-off-on, I've got one on the 110 running the rear lights ("on", "off" and "reverse")
MobileCentre have just the switch I need - going to call Tim now
