Home > Maintenance & Modifications > Where do the speakers mount? |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Roof mounted speakers? In a Defender?
Never knew Landrover did such a thing I'd guess its an aftermarket/self fitment jobbie ... in which case you'll be on your own, all down to trial and error Guns and Landrovers .... anything else is irrelevant. |
6th Aug 2012 8:26pm |
GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555 |
Speakers as seen here.....
Click image to enlarge An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
6th Aug 2012 8:47pm |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 |
I've saw a picture a short while ago and thought that was a great spot as I've a DC
Someone may have a pic of a roof with no head lining I hope It's good to be back from the dark side DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
6th Aug 2012 8:48pm |
Thanks Dave, it's the 'trial and error' bit that gets to me An engine to TDi for!
Ok the ones I saw were in the back section It's good to be back from the dark side
6th Aug 2012 8:50pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
You said you removed the speakers AND headliner. Are you sure the bracket you mentioned is not for the headliner attachment and the speakers were just screwed into the headliner. In my Puma 90 the rear speakers are fitted in the rear each side of the rear door, below the rear side windows. Yours look like a DIY fitting. LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
6th Aug 2012 9:18pm |
Oops ! I never thought of that That would certainly make sence
Thanks for your help An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
7th Aug 2012 7:06pm |
No problem. Hope you get it sorted and happy listening. LANDYWATCH
7th Aug 2012 7:14pm |
