![]() | Home > Maintenance & Modifications > Which paint? |
| Thud Member Since: 21 Jul 2012 Location: London Posts: 667
Now my silver chequer plate is black the headlight surrounds and grill look wrong. What would be the best paint to use to spray them black? Any protective top coats required?
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
I have used Plastikote on my window catches and Patriot roof rack mounts. With the undercoat applied it is easy to apply and you can apply several coats in a short amount of time. It is in my opinion very good and will be more than suitable for the use you have planned for it.
Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 6th Aug 2012 9:12pm. Edited 1 time in total |
| SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527
Primer http://www.ebay.co.uk/itm/U-pol-Plast-X-Pl...215wt_1165
Top coat http://www.ebay.co.uk/itm/U-pol-Plast-X-Pl...207wt_1165 993 Varioram - Guards Red Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
Perfect, thanks!
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
For not much more than the cost of those paints you can buy, again via eBay, a brand new grill and headlight surounds that are already black. Would save a lot of faffing around. Darren
That's true. In fact probably just as cheap. Full set new for £40 it seems.
AAAgh! from pillar to post and back again! Okay I'll go for the paint then!
