![]() | Home > Td5 > Oil contamination question from a numpty! |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6039 ![]() ![]() ![]() |
Welcome along
In the past I have just unplugged the red plug from the ECU (after making sure the ignition is off) not had an issue. Just remove the seat base (pulls up from the two clip things either side), remove the plastic trim, unclip the lid and remove and there is the ECU. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Sparspotter Member Since: 10 Jul 2012 Location: northwest Posts: 15 ![]() ![]() |
Cheers, thanks for that excossack...
I'm hoping not to discover anything too sinister, only had a couple of slight misfires recently but peace of mind before setting off on any travels. |
Goodluck. 1999 Defender TD5 110
Well, finally found some time to investigate possible oil ingress and I'm happy to report none - everything dry and as it should be.
Thanks again Excossack for the tip - I can't believe last year I went to the trouble of unbolting the whole seat assembly when a tug on the base would have been enough - same as the rather basic seats in my old Series 111 which was my introduction to Land Rover ownership twenty years ago. |
Well done! glad to read its all dry. 1999 Defender TD5 110
