Home > Maintenance & Modifications > Replacing Alpine window seal
excossack
Last year I changed the Alpine window seal and used an after-market seal that I had to cut to length and sealed it with some windscreen sealant. The sealant has cracked and got hard and the windows is still leaking.
When fitting the window seal I noticed that there is a enough movement in the seal to allow the edge of the roof to be exposed if I was to push the seal enough.
Are the main dealer ones pre-cut to the right length or can you get ones that are complete?
Is there a correct length the new seal needs to be?
What sealant should I use?
Any tips for a non leaking seal? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #155396 13th Jul 2012 1:36pm
bob neville
John
I made the big mistake of buying ****part seals for the alpines on the 90 - never again !
The garage replaced my seals when it went in for service etc and used genuine seals.
I think they have to be cut to length but I am sure somebody will correct me Thumbs Up
2013 Defender 90 CSW - sold
Post #155402 13th Jul 2012 3:15pm
excossack
Hi Bob
I didn'nt ****Part seals AFAIK but not genuine ones. I think It will be worth while investing in the Genuine LR seals. I'm wanting a leak free LR! 1999 Defender TD5 110
Regards
John M0VAZ
Post #155411 13th Jul 2012 3:38pm
Bob
I think you are right too Bob. The rear quater panel windows in mine at the rear also have a join in the rubbers so suggests they are cut to fit. Surprising they don't leak with that alone Shocked ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #155414 13th Jul 2012 3:44pm
bob neville
My genuine seals and the sealing band have been well tested over the last month - not a drop of water through them Thumbs Up
I think they may have also sealed the rubber to the roof as well.
Post #155429 13th Jul 2012 6:02pm
excossack
Genuine seals it is then. I wonder what LR use to seal the rubber? 1999 Defender TD5 110
Regards
John M0VAZ
Post #155443 13th Jul 2012 7:23pm
ah, I know a bit about these. I had a leaking td5 and it turns out the inserts that fit in the middle of the rubbers were changed, they were made slightly wider to make a better seal, so when you get the rubber also make sure you get the wider sealing strip.
Post #155445 13th Jul 2012 7:40pm
excossack
Thumbs Up Very Happy 1999 Defender TD5 110
Regards
John M0VAZ
Post #155447 13th Jul 2012 7:46pm
