Home > Technical > Ruined air filter on the motorway!
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Two weeks ago I was on the M6 in what can only be described as Noah's ark conditions. Overtaking a lorry up Shap at about 65mph, when the engine stuttered. Backed off a bit and was expecting to pull over, but it carried on as normal after that so I left it.
On getting home and fiddling with the car, I notice the air filter (standard LR paper one, only a few weeks old) has warped and looks like it's been wet, although it has now dried out. The pleats on the bottom are splayed and some have lumps of dirt in.
Can't quite work out how this has happened. I have a snorkel, sealed to the bodywork. Checked the air inlet and no holes or damage - likewise the filter box. Haven't been wading for over a year. The only thing I can think of is that the spray off the lorry and other vehicles was at exactly the wrong height and overwhelmed the air intake. Guess it'd be pulling air in fairly hard at 65mph.
Anyone else had this happen?
Confused of Cumbria
Post #153868 6th Jul 2012 8:41am
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Our 07 reg has been known to loose power, completely randomly when overtaking uphill - Namely the bottom of telegraph hill at the end of the M5 - start of the A38. I never got to the bottom of what it was - only done it twice in all. I don't think it was water related, but could well be wrong. I'd have thought that if yours was getting that wet that you would have done more damage than just a small cut in power?
Alex 110 Tdci Double Cab
Post #153873 6th Jul 2012 8:55am
BigMike
check the drain hole in the base of the air box. I have had water rush up that and cause a drenched filter/stuttering engine. It's happened when going through standing water at speed.
solution is seal it with RTV sealant and also the airbox too. My snorkel top was turned the opposite way too to stop water getting in that way
Post #153877 6th Jul 2012 9:24am
twopoint6khz
Right, didn't even realise there was a drain hole in the air box (being a short arse I can't see down that far), so I'll have a look at that with a view to blocking it up. Don't think I can turn the snorkel top round as it's a Mantec one not a Safari. Ta
Post #153881 6th Jul 2012 9:38am
Dave-H
This is a well documented fault with the Mantec 'plastic jobby' RAI .... have a look on LRUK forums, plenty of people having same issue.
Have a word with Mantec, others have. Doubt they'll do anything, but at least they'll know it's a more common problem. Guns and Landrovers .... anything else is irrelevant.
Post #153914 6th Jul 2012 12:52pm
K9F
Dave-H,
Link won't work unless you're registered and log in! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #153921 6th Jul 2012 1:15pm
Dave-H
K9F wrote:
Dave-H,
Yep, you're right .. can't bypass it either so link removed Rolling Eyes
Sign up to forum, then search 'Mantec Snorkel' in the Defender section ... Guns and Landrovers .... anything else is irrelevant.
Post #153926 6th Jul 2012 1:27pm
landy andy
Have had the same happen to mine with mantec snork on, and mine is fully sealed, it sucks in the spray.
Andy
Post #153964 6th Jul 2012 5:32pm
