Home > Maintenance & Modifications > 110 Receiver Hitch - Suggestions?
SimonR
So far, I've bought two different receiver hitches which are supposedly to fit Td5 & Puma. However, neither did! I think they were designed to fit early Td5 and assumed that just by changing the bolt holes where it bolts to the bumper, it would fit later vehicles.
Unfortunately, to fit, I would need to cut a chunk out of the fuel tank - which is not high on my list of modifications Wink
Can any of you recommend a receiver hitch that does fit a late Td5 / Puma?
Si
Post #152559 28th Jun 2012 9:23pm
LRSoffroad
what make was they ??
Post #152561 28th Jun 2012 9:25pm
SimonR
One was from the chap who I think is a friend of David Bowyer - often shares a stand with him. The other was bought from Billing last year - but I cannot remember who from. One of the many people with side bars skid plates & the like.
David's friend very helpfully suggested I could modify it myself - but having had another look at it this evening it would be simpler to make from scratch! He did offer to replace it IF he made one that actually fits.
Si
Post #152584 28th Jun 2012 9:57pm
landy andy
The one on mine 04 reg Td5, but a 90 was made by safari equip, and fitted straight off, well made bit of kit, but that could be who you got yours from?
Andy
Post #152588 28th Jun 2012 10:00pm
leeds
EXACTLY what vehicle do you have? TD5 or Puma? What year?
Has it had rear cross member replaced? Is the fuel tank the original type of fuel tank?
Lots of questions but it can be difficult to say what will fit as LR can be modified.
Please note that a tow ball attached to a 2" receiver drop plate is NOT type approved
Cars require type approval on tow bars since about 1997. However commercial vehicles do not require type approval on tow equipment.
Brendan
Post #152597 28th Jun 2012 10:27pm
spudfan
Ireland
This is the Land Rover Puma tow hitch supplement. I hope it is of some help.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #152601 28th Jun 2012 10:38pm
SimonR
Spudfan, thats a good bit of info! I'll do a bit of measuring.
Leeds, I have EXACTLY this: An 03 Plate Td5 110 Double Cab
Si
Post #152622 29th Jun 2012 12:33am
Mountain_man
Wales
Would the Alko quick-change system work on a standard towbar for what you want Si?
http://www.al-ko.de/3551.htm
Post #152633 29th Jun 2012 7:52am
landy andy
Shame that Southdown don't still make thier version of a removable tow hitch on the tank guard, was a nice bit of kit.
Andy
Post #152636 29th Jun 2012 8:08am
Andy
I didn't realise that they'd stopped making these - what's the story?
The Southdown tank guard and removable hitch was a quality piece of kit, and was on my list of things to get one day.
Post #152646 29th Jun 2012 8:54am
SimonR
The Alko hitch looks like a nice solution, unfortunately to a different problem to mine anyway.
I need a drop hitch but I need it to be removable because it acts as a plough if you take the vehicle off road.
At the moment I'm continually removing and refitting the original A frame drop hitch but it takes half an hour and I'd like a better solution.
Si
Post #152649 29th Jun 2012 8:57am
Mountain_man
Wales
I Came across the Alko system in a german offroading mag. They appear to do all sorts of attachments for it including swan-neck towballs which lower the ball height by several( 6+) inches. All TUV approved. Would be quite expensive but you could have various height balls/recovery point/nato hitch etc for any application all on their own backing plates
Post #152771 29th Jun 2012 7:26pm
Michael Brindley
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Hi,Have removable tow hitchreceiver type on my 2007 110 origionslly bought from Scorpion Racing in 2007.Believe they are now Extreme 4x4 sold as quickly detachable towbars.Been very good tows heavy trailers ie access platforms and the caravan.Have various atachments including warn reciver shackles for recovery tow ball and jaw ftg and aalco stabaliser hith.
Post #152774 29th Jun 2012 7:31pm
T1G UP
ah the reciever hitch nightmare
well i bought one....and it fell to bits after 21 miles.....the trailer left the rear of my 110. Fortunately i was slowing to a stop when it broke and little damage was done apart from wiring.
I'd look into the alko system. Never again will i trust a mig monkey who thinks he can weld when it comes to towing. Had i been towing a caravan or a car trailer with a car on it wouldn't of lasted 21 miles and could of killed someone.
a tyrpe approved or a TUV approved systems the only way to go.
buyer beware!
Post #152785 29th Jun 2012 8:23pm
Andy
I've got the original Southdown detachable hitch off of my 110 tank guard here. I've never used it (bought it all second hand) and it looks like the prevous owner only used it a bit.
i could be tempted to part with it if the price is right, as I never tow anything with the 110 (it has a NATO hitch on the back anyway)
Pics to follow
Post #152847 30th Jun 2012 11:15am
