![]() | Home > Tdi > Rear Corss member |
iPints Member Since: 15 Jun 2012 Location: SC Posts: 294 ![]() ![]() ![]() |
Hello all I am new to this forum......
I have had my defender now for 5 years and last year i stripped back my rear cross member and then painted it with "Kurust" then an red oxide and undercoat and finally two coats of Smoothrite flat matt black.... A year on and the rust is back.. ![]() |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Welcome...
Ku-Rust and most similar treatments will only acid treat rust on the very surface, it doesn't penetrate very well, you have to make sure you take the rust right back! I would get it right back to bare metal and do as you did before so the Ku-Rust will act on any surface rust pitting that isn't too deep. No need for red oxide and Ku-Rust though, Smoothrite will go straight over the Ku-Rust, the red oxide isn't doing anything in your case, (never does much anyway! ![]() Could try Fertan next ![]() http://www.fertan.co.uk/Item-Fertan%20rust%20converter.htm No need to sand/shot blast apparently ![]() |
Thank you both for very quick response.
I did bring the whole thing back to bare metal but I think the areas of rusting needed more work.....I will try again when we get some decent weather!! So maybe next year then..... ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21019 ![]() ![]() |
A grinder to start taking care not to take too much off or not to gouge it into the steel. And some sand fine sand paper to take out the imperfections ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
