Home > Puma (Tdci) > strange noise from the front when towing
rossy
just back from a 7 hour round trip to Cookstown Caravans in Tyrone where I had a load of warranty work done.
I've noticed that when pulling off whilst towing if there aren't sufficient revs or if you're pulling off uphill theres a momentary clanky rattle from the front. This also happens if you change down to too high a gear while going slowly (eg second where first would have been wiser).
The noise sounds like its coming from the front diff or maybe half shafts (or maybe its the gearbox) and it feels like something is being laboured momentarilly and just rattles in a clanky sort of way. It only happens when towing (about 1500kg) and only occurs in 1st and 2nd gear.
Has anyone experienced this and is anything wrong ? Thanks
Post #150196 13th Jun 2012 7:41pm
BigRuss
When I first read the subject of this thread I had to ask if you'd tried hitching the trailer/caravan to the back instead of the front Rolling with laughter Russell
2011MY 110 XS USW Black
Post #150202 13th Jun 2012 7:57pm
rossy
oh dear no one else appears to have had experienced this
well I hope its just a 'characteristic' then Confused
Post #150990 18th Jun 2012 6:43pm
ickle
Hi Rossy,
Yes mine makes strange noises as well, first gear, no accelerator just moving slowly across a field etc. I thought it was backlash in the transfer box, but there's so much back lash everywhere, it could be anywhere!
Keith
Post #151028 18th Jun 2012 8:29pm
DMAKX
Scotland 2012 Defender 110 Puma 2.2 USW Santorini Black
Hi Rossy,
Mine is exactly the same. It can even do it if you labour the engine when pulling away in second too.
It clears once the revs are sufficiently high enough though.
It does make you cringe a bit when you hear it, but I guess its one of those many Land Rover traits. Laughing
I can't recall my 2.4 making the same noise but it does sound as though it is coming from the transmission rather than the engine.
DMAKX
Post #151088 19th Jun 2012 8:46am
rossy
thanks lads for those words of comfort ! Thumbs Up
Post #151166 19th Jun 2012 6:05pm
