Home > Maintenance & Modifications > TD5 tuning options? |
There is a multitude of options....look through the sponsors give them a call. You could also do a search or two, just typing 'tuning' throws up 284 threads.....Happy reading!!!!! If you go through life with your head in the sand....all people will see is an ar5e!!
10th Jun 2012 9:15am |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
We at BAS offer various products from remap tuning to Allisport intercoolers and our well know TD5 VNT bolt on hybrid turbo charger.
My self at BAS and Ian at IRB Developements are the only companys that have a bolt on TD5 VNT conversion that was designed and made with the TD5 in mind at casting stage. The turbo as said is a direct replacement unit and does not need new special intercooler hoses and pipework to make it fit like others on the market. Link here http://bellautoservices.co.uk/products/vnt...vgt-turbo/ This turbo can be fitted with or without an intercooler and will also help with power on cars with or without remap or electronic tuning. It will help with low end power being a VNT and will also help throughout the full rpm range to maintain boost/flow upto redline, This bolt on VNT option is far more effective than the standard fixed geomitry turbo at doing its job improving the cars drivability and pulling power no end. Regards Pete |
10th Jun 2012 10:44am |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 652 |
I can vouch for the fact that even a simple remap (done right) makes a world of difference
Mine will now properly push you back in your seat in 3rd |
10th Jun 2012 6:28pm |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 |
thanks for the replies lads, loads to keep me busy on nightshift tonight then
10th Jun 2012 6:43pm |
