![]() | Home > Maintenance & Modifications > Budget bridge winch to fit in Mantec Defender bumper tray |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
I now have a Mantec winch bumper , the 5-WB that allows me to use my rubber A bar & keep the a/c clear. http://www.mantec.co.uk/productdetail.cfm?...D0F12999FB
http://www.mantec.co.uk/images/products/fu...0A-BAr.jpg Will any other, cheaper, bridge winches fit as the Warn show does?[/img] Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6024 ![]() ![]() ![]() |
Maybe something from the David Bowyer / Goodwinch collection might? http://www.dborc.co.uk/goodwinch/ 1999 Defender TD5 110
My plate is attached to the top of the A bar 1999 Defender TD5 110
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196 ![]() ![]() |
The GL5 bridge winch does not fit where a Warn once was, it does physicaly but only just but you will need to re-cut and then weld up the fairlead hole as it is more centraly located and re-drill the base plate, just had to do it tryed to up load pictures for my Ladybird thread but my gallery is full at the moment If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
Good winch tds 9.5 about 450 Ish 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
