Home > Maintenance & Modifications > Top tip to deter Defender door theft
Dave-H
Owing to recent incidents of door and bonnet thefts from Defenders, i was looking at various replacement door hinge bolts without much success Crying or Very sad
Whilst pondering the idea with me, a workmate got out his vernier, had a measure and said "Why dont you just superglue a 5mm ball bearing into the head of each bolt"?
Bloody brilliant ! Cool
We did a loose bolt as a test, and it proved dam near impossible to remove the bb owing to snugness of fit and shape.
Mine now all have a 5 mm bb in place .... might not be foolproof, but makes it one hell of a job to unbolt, looks pretty tidy too Thumbs Up
Just make sure you 'nip' the bolts up tight first, if a door hinge comes loose afterwards you'll be hard pressed to do anything about it Whistle Guns and Landrovers .... anything else is irrelevant.
Post #148477 3rd Jun 2012 10:06pm
Retroanaconda
I like the idea, but the prospect of drilling out all those ball bearings/bolts in 10-15 years time when the hinges wear out would rather put me off!
Suppose you could just do one on each side of each hinge.
Post #148482 3rd Jun 2012 10:35pm
spudfan
Ireland
[quote="Retroanaconda"]I like the idea, but the prospect of drilling out all those ball bearings/bolts in 10-15 years time when the hinges wear out would rather put me off!
I do admire your optimism Whistle Laughing 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #148493 3rd Jun 2012 11:53pm
noworries4x4
I have just filled up the heads with 2 part epoxy glue at least i can chisil it out if needed with a centre punch but will put most opotunists off. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #148510 4th Jun 2012 9:31am
A good idea but hardly original - it's been on this forum more than once before.
Post #148536 4th Jun 2012 11:31am
K9F
Re: Top tip to deter Defender door theft
Excellent idea! Thumbs Up Great minds and all that... Same one I had in January....pictures here...
http://www.defender2.net/forum/topic8589-15.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #148579 4th Jun 2012 4:02pm
Dave-H
Must of missed that ... would of saved me putting my grey matter to the test lol Laughing Guns and Landrovers .... anything else is irrelevant.
Post #148619 4th Jun 2012 8:56pm
