Home > Camping, Caravanning and Holidays > Awning skirt.
Lorryman100
Awning skirt.
Thought I would share how I attach the awning wheel skirt cover without drilling and screwing on the poppers.
I bought several large suckers from a company on the bay and then using stainless steel screws fixed the stud onto the sucker.
The suckers stick onto the side of the van with no issues except for on my new van there is a reflector in the way stopping one of the suckers from fixing. Turned out it was not needed. As my last and current van is a twin axle I managed to get a suitable wheel cover from Isabella and it needed 5 suckers. A single axle cover would only need three.
As you can see a lot of strain was put on the suckers, yet they do not come off.
HTH Brian.
Post #148435 3rd Jun 2012 4:47pm
Nick T
England 2010 Defender 90 Puma 2.4 HT Galway Green
Brilliant but simple. I'll be doing that Very Happy
Post #148439 3rd Jun 2012 5:35pm
WarPig
Very impressive Brian Thumbs Up And a great looking outfit youve got.
Some vans have press studs on the side panel for the wheel awning skirt to attach to. I guess new vans dont have these nowadays?
Post #148442 3rd Jun 2012 5:47pm
Lorryman100
Cheers Steve, Thumbs Up
The studs come with a new awning and chances are that a previous owner fixed them onto your van. I was always worried about the 6 year water ingress warranty being voided if I fitted the studs the way they are supposed to be fitted. After all there is no sealant used in the instructions for fitting, but I would like to think if I did do it the official way I would coat the screw and stud face in sikaflex before fitting. Then again, I cant face drilling five holes in my vans body just yet Shocked
Brian.
Post #148443 3rd Jun 2012 5:54pm
WarPig
Agreed, no way would i drill into a new van. Shame the manufacturers dont factory fit them. Im now paranoid my studs might need resealing Shocked
You mention Sikaflex, would you recommend this for rebonding my friends awning rail back on as the original sealant is failing?
Post #148446 3rd Jun 2012 6:10pm
Lorryman100
I use it on the boats and cant fault it. It is an adhesive that flexes which is what you are after on a caravan as the whole body shell does move in transit and with hot and cold weather. The boats flex as they are fibreglass and sikaflex is used to bond panels, fill in holes, seal bungs, cover outboard mounting bolts and nuts etc etc.
There is specific caravan sealant which is flexible though so may be worth investigating first? Also when the rail is refitted using the original size of mounting screws they may offer some movement due to flexing damage depending on the age of the van, so a flexible adhesive sealant may be a better option than going up a screw size? Just my thoughts Thumbs Up
Brian
Post #148450 3rd Jun 2012 6:22pm
WarPig
Useful advice, thanks Thumbs Up
Post #148460 3rd Jun 2012 7:12pm
rossy
thanks Lorryman
that's one of those 'why didn't I think of that ?' ideas. For years I've always kept the same bits of velcro stuck to the caravan (with the corresponding bit on the wheel cover) but of course they look unsightly and manky after a while !
Post #148811 5th Jun 2012 10:44pm
Henry8090
Hi,
Just thought I had to post my thanks to you for the idea. I did as you described and am thrilled with the result!! Can't believe I've messed about all these years, propping things in front of the wheels etc to avois drilling...brilliant idea. Very Happy
Post #413787 4th Apr 2015 6:04pm
gilarion
What a brilliant idea and one that is simple as all great ideas are Thumbs Up
Could you provide a link for the suction cups or what type they are there is so many on ebay its all a bit confusing Smile For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #413793 4th Apr 2015 6:30pm
