![]() | Home > Td5 > Heated screen connection |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18021 ![]() ![]() ![]() |
Not unless the vehicle left the factory with a heated screen fitted.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6046 ![]() ![]() |
No, not standard fit on the hardtop, so will have to wire from scratch then
![]() ![]() Andy |
bmc054 Member Since: 02 Jul 2011 Location: Doncaster Posts: 32 ![]() ![]() |
HI
I bought a wiring kit for the job all relays timers cables included ready to fit from mobilecentre who are now sponsors on here,the chap was really helpful too ![]() |
Ohhhhh, like the sound of this. Can I ask rough cost? Will save messing about ![]() Andy |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
Here is a "generic" kit including the OE switch
http://www.mobilecentre.co.uk/land-rover-d...p-694.html This is fused at 30A (350W) and is a single feed for the screen which will suit OE Pilkington screens. Some aftermarket screens require a dual input which can be supplied as well. We can also supply with a Carling switch or just the timer relay and you build your own |
Thanks for that
![]() ![]() Looks like that's the easy option I assume it's just plug and play? Andy |
Connections have to made that are not plug in such as power from the battery and illumination pick up from a nearby switch.
It is as close to factory as you can get in a pre assembled kit form. |
