![]() | Home > Technical > Ticking noise from fuse box / dash board |
I would suggest ....... PANIC
![]() If I remember correctly there are relays in that fuse box and it sounds like it could be one of those energizing and discharging. After my recent experiences with Puma electrics I am very careful about doing any mods. Maybe pull the box cover and see if you can identify if it is a relay and, if so, which one. Might give you a clue as to what is going on. I am sure one of are resident sparks will be along to give you a proper explanation ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
like Bob says, take the lid off the fuse box and put your finger on each of the relays, you can feel them click
also, disconnect the 2nd battery to see if you have upset the system |
