Home > For Sale & Wanted > Wanted 110 County or XS |
cradgebank Member Since: 30 Dec 2008 Location: Nottingham Posts: 306 |
Hi
Looking for a late Td5 or preferably Tdci 110 Station wagon. Thanks Richard |
17th May 2009 7:00am |
Landy nut Member Since: 22 Dec 2007 Location: In hiding Posts: 154 |
Forgot to say - also has full LR original rubber mats, alloy gearbox and transfer box knobs and rear tinted windows for rear passenger compartment, to include rear sliding window and small curved windows. This was done by a top tinting company at great expense in Devon.
No body work corrosion or electrolysis etc anywhere and as it is a late one, it has all the new pressed frame doors, rather than the angled ones, so is much less prone to rot!!! Full adjustable towpack (LR fitted from factory). New door seals were done. Will add more things as I think of them!!! She sounds and drives as new and everything is really tight on it. No noises, rattles or squeaks and everything works perfectly on it. Gearbox is lovely and tight. |
17th May 2009 5:34pm |
To give you an idea of what I mean by fastidious owner, when I do my oil changes, I coincide them with the changing of the seasons, as the colder winter temperature and hot running causes more condensation and therefore water to sit on the oil and in the engine, so I change my oil and the right time of the year, every 5-6k.
I also do a double change every time, in that I buy double the amount of oil required and 2 filters. I do one oil empty, the do the first change with new filters. I then run this for about 1-2 days maximum and then redo the entire oil change with new filters again. This keeps the oil much cleaner and greatly reduces the amount of junk in the oil that ends up sitting around the engine after you drain the first time. I flush and operate the coolant system and the diffs and gearbox and transfer box and the brake fluid in the same way. You get the idea...... I am officially a nutcase when it come to maintanance. |
17th May 2009 6:03pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
sounds like you've got mechanical O.C.D NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
17th May 2009 8:59pm |
PM sent to you Landy Nut
18th May 2009 6:19am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Landy Nut - why are you selling? Sounds like you have a dream spec. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
18th May 2009 8:42am |
Yes, I do have mechanical OCD!!!
I was thinking about keeping it until the new one came out, but I have decided that I am going to change a few years earlier. Who knows, I might get bored in a few years and swap back if LR get the new Defender sorted. It really is the perfect truck, I have to admit and it will really hurt me to get rid of it as I have spent a lot of money on it with regards to parts and ensuring that it gets nothing but the best. I will be gutted to see it go, but as long as it goes to a good home I will be happy. |
18th May 2009 9:11pm |
Still looking if anyone has anything.
15th Jun 2009 9:14am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
My 110 xs utility is for sale
Click image to enlarge |
15th Jun 2009 1:57pm |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
Really? |
15th Jun 2009 4:23pm |
Yep |
15th Jun 2009 11:12pm |
PM sent Andrew
16th Jun 2009 6:33am |
