Home > For Sale & Wanted > For sale.... one mans' trash is another mans' treasure
Mountain_man
Wales
Need to empty my shelves as loads of stuff has accumulated over years and most will never be used by me again. So all is up for grabs. Some obviously has a proper value so will sell at sensible prices. Other stuff I have priced to move to a new home where it might be of value. Open to offers on all of it if you think it is too overpriced lol. I have 9 pages of bits so apologies for long list!. Photos on request.... most of it looks like every other thing that looks the same. Google will show you if in any doubt what something is! No hurry to shift stuff so transport may be possible via various challenge events/land rover shows etc but happy to post/courier at cost. I use Interparcel.com and most stuff seems to fall in the 2-20kg bracket and is around �7-�10. Collection also possible from SE Wales not far from Hereford. PM me in first instance if interested. I fear I may get confused so please bear with me. Will be at the Whitbread Challenge next weekend so can bring stuff there for couriering on or collection. Unless otherwise stated all stuff is used and while sold as serviceable you should not expect stuff to be in "as new" condition....
Disco bits (may also suit RRC)
2. 2x 300 tdi disco drag links with TREs (�5 each)
3. 2x 300 tdi disco track control rods (�5 each)
25. 1x 200 tdi disco washer bottle with headlamp washer pump still attached (�5)
26. 1x 300 tdi disco washer bottle with all 3 pumps still attached (�15)
27. 2x 200 tdi disco long door pull handles in blue. �2 the lot
28. 1x complete set of disco 200 tdi middle row seatbelts (�10)
29. 1x as new Monroe steering damper for Dsico/RRC (�10)
32. Set of 300 tdi disco clocks at 123K working order (�5)
33. 3x disco 300 upper rear light clusters 1x NS 2x OS, all good. (�10 the lot)
34. 6 disco 300 binnacle switches 4x radio 1x heated screen 1x rear washer (�5 the lot)
36. 1 200 tdi rear light cluster NS. Some damage on edge but would pass MOT (�2)
37. 200 tdi disco NS mirror. Good. (�5)
38. 1x genuine AP clutch master cylinder for 300 tdi disco. Brand new in box. (�30)
39. 300 tdi disco PAS pump. Genuine. Changed as believed to be leaking but turned out to be split pipe. (�15)
40. Pair of 300 tdi disco mirrors. Casings good, no glass and one has damage to mounting (broken plastic clips)> Make one good one from the 2 if you need one. (�5 the pair)
41. 1x 200 tdi intercooler. Conditon OK (�5)
61. 5x 24 spline disco/RRC CV joints and loads of matching front shafts, some surface rust (�25 the lot)
62. 1x front propshaft from V8 300 series disco, good. (�15)
63. 1x rear prop from Disco V8 with rubber donut (�15)
44. 1 300 tdi disco subwoofer assembly with amp and speakers. Untested but look fine. Grill a bit dented and plastics are scratched. (�15)
45. 1 disco 300 OS indicator (�5)
46. Pair of good 300 tdi disco headlamps (�15)
55. 1x 300tdi disco window winder mechanism with motor, drivers side (�5)
47. 1x disco wiper motor assembly, working (�5)
48. Pair of brand new genuine side finishing strips for 300 tdi windscreen (�5)
50. 3x early disco stubby CV joints and 2x short hub shafts to match. (�15 the lot)
57. 1x pair of long & short rear 24 spline shafts with mushroom ends (�15)
58. Disco 300 grill and headlamp finishers in black. Good condition (�10)
66. 300 series disco front fog light lens NS (�2)
64. 200 tdi disco stalks, good (�5)
Defender bits
12. Early defender speedo head showing 148K miles (�10)
13. early 110 heater plug resistor, may suit series diesel too� (�2)
20. 1 pair of front callipers from a 200tdi 110. One serviceable, the other needs rebuilding due to rusty pistons (�10 the pair)
21. 1 complete set of 4 pistons and seals to rebuild a defender front calliper but not sure which type of calliper. PN 606683 (pistons) & AEU1547 (seals). These are Britpart/allmakes. (�5 the lot)
22. Pair of wiper wheel boxes from early defender, working OK. (�5 the pair)
23. A gear set for early defender wiper motor, working fine (�5)
79. Freshly galvanised spare wheel well for 110 pickup (�15)
80. Covers for battery box and tool box from 200 tdi type seat box (�5 pair)
81. 200 tdi gearbox mounts with new rubbers (also fit V8 engine and box) (�10)
52. 1x defender sidestep. OK condition but will need folding mechanism freeing up. (�10)
69. 200 tdi type rear prop for 110 good (�15)
70. Rear tailgate for Defender pickup, good condition (�45)
71. 1x pair of 110 trailing arms with good bushes (�20)
72. 1x rear bench seat for 90 or 110, as new. (�15)
73. A complete set of 3 cloth trim front seats for defender. Very good condition with only one tiny nick on rear of drivers seat. Complete with runners (�150 the set)
74. 110 chequer plate sill covers, used! (�10)
75. Battery box and tool box removed from 200 tdi type seat box. Repaired and both in reasonable condition. (�20)
76. 110 trailer brake vacuum tank (�5)
83. Complete front axle from an early 110 in good clean condition No leaks and swivels are good. Still has steering arms, disks & calipers (good condition but need pipes), radius arms, panhard rod and wheels with very good tyres (Yoko Geolanders in 235/70 flavour) . Would bolt straight onto a 110, 90 or disco. Has the stronger AEU-type CVs. (�100)
Universal bits/offroad bits
1. 2x panhard rods (�5 each)
5. An old Warn motor from early 8274, possibly 2.6hp??? Untested & painted blue (�5)
6. Home made bracket for 2nd alternator to fit 300 tdi Aircon compressor position. Complete with a subaru 65 amp alternator with 4pk pulley and multiplug/wires. I have a belt somewhere that fits and runs on the 300 tdi fine. It was a freelander belt so easy to get another if I can't find it. (�30 the lot)
7. Left overs from a 200 tdi head gasket change, several gaskets and a full set of valve seals, I only used the head gasket. (�1)
14. 1 standard rear shock top mount and chassis bolts (�2)
15. Front and rear spring seats for disco/90, loads of them. �1 a pair.
19. 1 pair of almost new (300 miles on truck) 300 tdi rear callipers. Not genuine but not britpart either�. (�40 the pair)
30. 1x pair of unused ProComp gas shocks. NOT a Land Rover fitment. Pin to eye fittings with pin at the top. Bush to bush centre measurements are 16� closed, 25.5� open. (�20 the pair)
42. 1x tdi expansion bottle/header tank. Black type but in good condition (�5)
43. 1 metal expansion tank, possibly from V8? (�5)
49. 1 10 spline diff � Rover type. Undamaged. �20
51. 1 standard 8274 mainshaft (what is left after fitting a GP uprated one) (�15)
56. 1x pair of standard pin to pin front shocks (�5)
60. Wheel brace for land rover (27mm) and a wheel chock (�5)
67. 1x pair of alloy spacers for 8274 to fit to ARB type bumper (�15)
77. 1x pair of heavy duty front shock turrets. Unknown make but very strong, Standard height. (�20 pair)
Post #146019 20th May 2012 12:49am
GUM97
PM sent.
Post #146160 20th May 2012 9:09pm
