Home > Td5 > Pressure regulator noise |
Andrew DefenderBits
Are you talking about the reg on the rear of the TD5 motor, just thought I'd check as it's in the TD5 section but your signature says you have a newer truck
If it's for a TD5 then the fuel reg can be rebuilt, you just need a Viton Seal kit and a block gasket and away you go!
18th May 2012 10:34am |
