![]() | Home > Technical > Steering box - In the nick of time |
roadracingtog Member Since: 03 Nov 2011 Location: Cheshire Posts: 97 ![]() ![]() ![]() |
With less than 30 days warranty remaining on my 2009 110 I discovered a leak of oil from the bottom of the steering box. Without delay it was off to Hunters in Chester. As ever no quibbles, booked in Monday for a new steering box to be fitted. Which is fine but it does disappoint me that after just 16,000 miles the steering box has failed
![]() Any other experiences? http://www.roadracingsupporters.com |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Mine was replaced during it's second service .... 11k on the clock
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
my power steering failed on my td5 within 24,000 miles from new (2 years old) and was replaced under warranty.
are the td5 and puma units the same? |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 655 ![]() ![]() ![]() |
Steering pumps on Defenders have been a weak point since er, they were first introduced. My old 110 (1986 vintage) used to intermittently dispense power steering fluid onto the tarmac.
The seals go, but it's such a ![]() Pretty sure the design is the same/very similar in the new ones (certainly Td5s) as it was in 1986? |
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 ![]() ![]() ![]() |
Staffs' 4 x 4 just replaced mine with an Adwest recon' unit. £390 all in.
How much did LR want for a new un'? £950 odd! Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 ![]() ![]() ![]() |
I had mine changed after 18 months with 15 K on the clock. My discos been through 4
![]() 98 V8 Disco |
