Home > Td5 > Noisy fuel pump |
defninety Member Since: 13 May 2010 Location: Warwickshire Posts: 37 |
Final thing that may be worth checking if not already done so....
Click image to enlarge Click image to enlarge |
4th Jun 2012 1:07pm |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
The O-rings are green tinted. These are suitable for contact with fuel and oils, which would break down a plain rubber O-ring. BTW, LR manufacture the Td5 Fuel Pressure Regulator using standard rubber O-rings, which explains why some leak from new. If you are going to rebuild your own FPR, you ideally need to also chamfer off the internals. This poorly manufactured metal can damage the O-ring when they are inserted, thus why the odd one can leak from new. There is a recent (December 2011) SSM (SSM34046 - TD5 Cylinder Head Damage At Injector Location Bores) on TOPIx outlining why and how to do this, as if it is not done correctly, the injectors could be damaged, and also there is the possibility of the head being cracked and leaking fuel into the sump. If you use the correct SPX tool for this job, it is idiot proof anyway. The lobe has to be in this position otherwise the tools will not fit. If you are using a heel bar or something to force it out, then beware. |
4th Jun 2012 8:43pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
Well just sent trilicklandrover an email regarding the seals
New ones from landrover being ordered tomorrow hmmm I just hope it isn't something else Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
5th Jun 2012 11:43am |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
That's why I'm waiting. I'm wondering, if they were not as described, can I claim the cost of repairs? |
5th Jun 2012 11:50am |
Yer true s ii said befor seems strange both from the same place Both gone wrong in a matter of miles ?!
5th Jun 2012 11:52am |
have you found anything out laurie
steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
6th Jun 2012 5:20pm |
They're road testing it tonight, Will find out in the morning. |
6th Jun 2012 11:49pm |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 |
mine went noisy recently after changing the fuel filter - apparently quite a common issue according to my Landrover mechanic mate. I got one of the £80 ebay ones to replace it and he said it was near enough identical to a genuine one that was going to cost easily 3 times as much.
Hardest part was getting the flippin fuel tank out to change it |
7th Jun 2012 12:50am |
Arbman Al Member Since: 04 Jan 2012 Location: Surrey Posts: 80 |
Received my proper genuine seals today, all in individual bags with landrover on them
When I took them out, to be honest, they did not look any different from the suspect ones I put up a photo for a few posts ago. Not going to change them just yet, as others have been changing them due to poor starting, lack of power etc. My pump sounds noisy (not had a td5 before, so might be normal!), and I do not have any starting issues, power loss or oil level rising - just only getting 16mpg 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
7th Jun 2012 8:14pm |
What colour are they? |
8th Jun 2012 1:40am |
I submitted the following to the seal suppliers this evening.........
Dear Sirs The items I received were not as advertised, i.e. not in original manufacturers packaging. They failed in less than 100 miles after being fitted by a reputable Land Rover service company. This company tells me that they were not original since original O rings are of a dark green colour. I require you to submit absolute proof of originality or refund my payment to you plus the cost of replacement by my service engineers. Yours, very sincerely Laurie Wright |
8th Jun 2012 1:57am |
The seals are definately dark green, where as the ones from Trillick were black. The washers look the same, bright copper colour (as in my photo above) 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
8th Jun 2012 7:47am |
No reply yet
8th Jun 2012 11:16am |
Just received......
Hi If you are not happy i will offer a full refund for the money you already paid us. Thank-you |
8th Jun 2012 12:10pm |
