![]() | Home > Puma (Tdci) > Mystery Plugs |
| sat13 Member Since: 06 Jun 2010 Location: Cheshire Posts: 70
Hi Everyone,
While looking in the area under the driver’s seat for an ignition live feed to run to a switch on the cubby box, I discovered two plugs that I cannot identify, one looks like an aux plug similar to the one behind the trim at the rear RH side and it has a white label on it with the number 7H12-14A005-LE the other is a larger multi type blue plug with heavy wires and a cover over it. The only info I could get is in the MY12 Electric reference library on page 43 it shows the larger of the two plugs with the numbers C1217, C1875 and C0621, All other electrical manuals do not show these plugs or any reference to the C numbers. I would like to know what these plugs are for and if I could use the small white plug for a live feed to my switch. Thanks to anybody who can help with this question. I am not sure how to put my pictures on the post but other posts seem to be using photobucket so I tried that, hope it works and my pics can be seen. 2009 Defender 90 XS 1999 Defender 90 300 Tdi http://s1258.photobucket.com/albums/ii529/fletch57/?albumview |
More info, I think the larger plug module is to do with the glow plug control. But the smaller plug???
