![]() | Home > Technical > Series Alternator conversion kit? |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Anyone know anything about this conversion? buddy in USA trying to find this bracket (not sure whether he wants the whole kit if there is one) for a 1980 series 111 Santana 2.25 diesel land rover, this part is sold out in the USA apparently.
https://www.dropbox.com/s/lo7ybocivfk7qb6/...ersion.pdf I've emailled back for more infer re what he wants, but for the time being and ideas if such a conversion kit is available here or is it just a USA thing. Cheers DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6723 ![]() ![]() ![]() |
The supplier have relabelled all the parts to their own scheme, however all the parts except the alternator plug have LR part numbers:
Qty PDF No PDF Description LR No. Full Description 1 RNE135 Bracket ETC4357 BRACKET - ALTERNATOR MOUNT 1 RNC446 Adjuster Bracket 568789 BRACKET - ALTERNATOR ADJUST 1 RNC445 Alternator Pulley 568788 PULLEY - ALTERNATOR 1 RNC788 Alternator Fan AAU3956 FAN - ALTERNATOR - SERIES III 1 RNC347 Alternator Plug ? ALTERNATOR PLUG 1 RND251 Bolt BH108161L BOLT M8 x 75mm 1 RND250 Bolt BH605121L BOLT 5/16" x 1 1/2" 1 RNC908 Bolt BH605161L BOLT 5/16" x 2" 1 RNA964 Washer 2266L FLAT METAL WASHER M8 THICK 2 RNE475 Nuts NY605041L NYLOC NUT 5/16" UNF 1 RND253 Bolt BH605321L BOLT 5/16" x 3 3/4" 1 RND252 Spacer 574948 SPACER FRONT COVER If it's the main mounting bracket, then it's a standard LR part - common to the diesel and petrol. It's pricey new (£170+VAT) ![]() However, the 4 cylinder 90/110/Defender also used the ETC4357 bracket right up to and including the 200 Tdi which should make one easier to find ![]() There are a couple of Series items on eBay at the moment: http://www.ebay.co.uk/itm/320896518953 http://www.ebay.co.uk/itm/190671311202 There are earlier and later variations (not sure what the eBay ones are - Series III engine suffix C is the change point). All it does seems to change is the thread used for the longest bracket mounting bolt [aka RND251]. Early it's 5/16" UNF, later (as used in this kit) it's M8 - Defender will be later type too. The early bracket is 574855 instead of ETC4357, and the early bolt is BH605261L (BOLT 5/16" UNF X 3 1/4") instead of BH108161L (BOLT M8 x 75mm). The full descriptions should help you find generic replacement bolts instead of genuine parts if you want. ![]() ![]() Last edited by Martin on 2nd May 2012 11:16am. Edited 2 times in total |
Thanks for that extensive information Martin, that might make it a bit easier for him to find what he wants as long as someone has one available.
Basically, any alternator-equipped 4 cylinder diesel or petrol up to and including a 200 Tdi will have the correct bracket.
Suddenly scrap engines are worth a lot more! ![]() ![]() |
