Home > Off Topic > Looks like Ladybird are going sailing and flying again. |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
Last year we did a job out in Poole Harbour, putting one of our tower cranes on the small Green Island, for erecting a new Canadian Log house, it was a great job to be involved with, i was horrified to learn that it has recently been badly damaged in a fire.
http://m.guardian.co.uk/uk/2012/apr/20/fir...pe=article Click image to enlarge Click image to enlarge If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
30th Apr 2012 9:39pm |
All that available water surrounding them and no contingency in the event of a fire? Saw the smoke....
Condor Ferries are currently using the jetty behind the tug as a maintenance berth at the moment. We are using the tug pictured The Herbert Ballam tomorrow to put divers in the water and fit a port outer jetavator on Condor Vitesse. Small World and coincidental photo.... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
30th Apr 2012 10:10pm |
I will let you know when we are going to start the operation again, loads of planning to get that lot out there, i have heard that the jetty and landing at the Island is much improved now. Still very shallow water in the area between the 2 islands. If everything is under control you are not going fast enough.
30th Apr 2012 10:49pm |
