Home > Maintenance & Modifications > Nas bumper+Mantec or Safari Equipe+Nakatanenga
familymad
Blank canvas 110 XS SW.
Wanted a NAS bumper but it seems only a Mantec wheel carrier will fit with this.
It seems some have gone down the Safari Equipe bumperettes and a Nakatenga carrier.
Thoughts? Does anyone have chequer plate kit with the SE and Nak set up also? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #141743 25th Apr 2012 9:11pm
I have the NAS step and a Mantec. really depends on what you are towing as to whether the NAS step works for you. BigRuss has the safari-equip wheel carrier and bumperettes from a forum sponsor (who'll no doubt be along in a moment).
the safari-equip wheel carrier is a real heavy-duty carrier, great for oversize wheels but does block the rear window somewhat where as the mantec is about the same as standard
Post #141753 25th Apr 2012 9:24pm
leeds
Personally I am not a big fan of NAS steps if you intend to do a reasonable amount of off road or green lane driving as it does degrade departure angle. For access into back, yes it is good.
Wheel carriers, basically readily available in the UK are the Mantec, Safari Equip and Nakatanenga wheel carriers. Others are available such as Kaymar, Pivlock, Britpart, Bearmach and Sonic/Alisport.
Mantec wheel carrier will fit with the NAS step
Mantec wheel carriers are about £240-280. Personal opinion I prefer the longer brackets of the Safari Equip ones.
Safari Equip do he largest range of wheel carriers and you can get them with/without hi lift carriers, powder coated, galvanise or galvanised then powder coated.
Must admit I thought the standard Safari Equip wheel carrier did not work with NAS step however looking at this Extreme photo
That looks like anSE one with the brackets to make the wheel more central. However I will have to check that information out.
Standard SE wheel carrier is
For post 2002 wheel carriers the SE ones start at about £196 for a stanard one for a Defender
Neither the Nakatanenga or SE single pivot wheel carriers will fit with the NAS step as they use the same bolt holes
For the SE one there is a slightly modified rear bumperette
The Nakatanenga one
It is wise to check the compatability of all after market gear prior to purchase.
We try to keep in stock the main Safari and Nakatanenga wheel carriers
HTH
Brendan
The Nakatanenga
Post #142379 29th Apr 2012 1:36pm
familymad
That's a concise reply brendan thanks.
So the SE single pivot one looks swell. I assume buying their carrier and bumperettes is the best option as it will all fit together with no mods required?
Does the picture with the silver '10 plate defender show a single pivot design and require no attachment to the body of the Defender? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #142474 29th Apr 2012 8:10pm
leeds
No modification to the body work however where it is bolted to the cross member some of those holes have to be enlarged so that some anti crush cans can be inserted.
We have one of the SE single pivot wheel carrier in stock. Am not 100% certain if we have a set of their modified rear bumperettes in stock or not. There again it is late on a Sunday night Razz .
Brendan
Post #142487 29th Apr 2012 9:12pm
That's an odd looking one, Brendan. It appears to be mounted above the rear crossmember and you can see that the fog light has been re-positioned to suit. There's clearly more to that than what can be seen in the picture :?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Darren
Post #142491 29th Apr 2012 9:25pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
It's the SE one that's sitting on my lounge floor waiting to be fitted when the rain stops
Its fitted using the the 2 bolts that hold tub on as well as a couple of extra ones as far as I can see and because mines to be fitted on a DC it will line up with the latch
All after I have relocated light and reflector according to distructions It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #142511 29th Apr 2012 10:06pm
leeds
I think yours is more like this one Sparky
Suitable for tailgates.
Brendan
Post #142514 29th Apr 2012 10:26pm
sparkylee
Yep that's it the wife hits her toe on the bloody thing every day and all I say is mind the paint, but the fixing methods the same I think via the tub bolts
Can't wait to fit it
And while your there any glove boxes in stock at the moment ? It's good to be back from the dark side
FFRR 4.2 vogue
Post #142518 29th Apr 2012 10:50pm
leeds
Yes we have the Nakatanega glove boxes in stock.
It is amazing how some threads wander away from the original post, just like a pub conversation.
Brendan
Post #142520 29th Apr 2012 11:01pm
familymad
Brendan is posting my 'modified' bumperettes today........
Start saving for the wheel carrier next 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #148084 1st Jun 2012 11:37am
Safari Equip swing away wheel carrier with NAS step - neither has been modified or lights moved ...
Post #148099 1st Jun 2012 12:30pm
familymad
It's the 'single pivot' one I want and that won't work with the NAS step 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #148100 1st Jun 2012 12:44pm
I know, my answer was for Brendan who wasn't sure if the two would fit
Post #148102 1st Jun 2012 12:53pm
