![]() | Home > Off Topic > Trailer/Load Width |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18028 ![]() ![]() ![]() |
Correct.
Also correct. Prior to the change this was only legal if the MAM of the towing vehicle exceeded 3500kg.
Yes and no, you can tow a 2550mm wide trailer with a load that projects up to 305mm on either side but the overall width must not exceed 2900mm. Anything over 2.9m wide falls under Special Types regulations. This width limit applies to all trailers, not just light trailers towed by M1/N1 type vehicles, so it applies even to semi-trailers and HGVs. Note: the Bateson Trailers website states that "the trailer must not extend more than 305mm (12”) outwards each side of the towing vehicle, irrespective of allowable width" but I cannot find any legal basis for this assertion.
A caravan is a trailer, and the 2550mm limit does apply to caravans, so a caravan wider than this is to all practical purposes illegal (the only way to operate a wider caravan would be to treat it as an Abnormal Indivisible Load and operate under a Special Types General Order). If you want confirmation of this, google will throw up copious primary sources. And, as a footnote, there is no doubt or ambiguity about the maximum permitted speed of N1 vehicles! |
Birdy Member Since: 07 Oct 2011 Location: CĂ´te d'Azur Posts: 887 ![]() ![]() ![]() |
Cheers!
And as for speed limits, I only use the Defender when I'm towing so use those applicable. The missus drives it the rest of the time, used to pilot a Beetle in banger races and drives like she still does so doesn't care... when you roll a Land Rover, a Brownchurch HD roofrack is a lifesaver. Peter |
