Home > Puma (Tdci) > Can any EGR experts advise, please?
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Not much response to previous query. 2010MY 90, engine running fine since recent service. I get the 5 EGR cleaning cycles on shut down, But It also seems to do 1 cleaning cycle on overrun. If I start engine and run it up to 2000revs then take foot of gas pedal I get an EGR cleaning cycle "chukka " noise. If I disconnect EGR plug then no noise. Is this normal? Bow down LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #139362 15th Apr 2012 2:04pm
ZeDefender
Off to try mine Thumbs Up Tell someone you love them today because life is short.
Post #139364 15th Apr 2012 2:32pm
ZeDefender
Can't hear anything from inside the cab - do you have your head in the engine bay? Tell someone you love them today because life is short.
Post #139366 15th Apr 2012 2:37pm
MK
it shoul not Puma 110" SW
Post #139370 15th Apr 2012 3:24pm
WelshGas
Thanks ZeDefender and MK. I was sat in cab. Didn't notice this happening prior to B service, a few weeks ago. Engine is running fine and Fuel consumption is unchanged. The only difference is this noise, which MUST be the EGR as it stops if I disconnect the EGR plug. Thumbs Up LANDYWATCH
Post #139373 15th Apr 2012 3:44pm
WelshGas
According to the Defender expert at the Dealership, this is normal. They offered a free health check including the EGR, so we will see. Whistle LANDYWATCH
Post #139615 16th Apr 2012 7:09pm
ZeDefender
I do wonder how you can hear it from the cab - either your engine is whisper-quiet (envy) or the EGR valve is sodding loud Shocked
I have to listen quite carefully to hear the self-clean cycle when I switch off... Tell someone you love them today because life is short.
Post #139621 16th Apr 2012 7:49pm
WelshGas
Not overly loud. Cannot hear with radio on volume 12 ( Land Rover unit ), but do tend to drive with window open. Thumbs Up LANDYWATCH
Post #139648 16th Apr 2012 8:45pm
ZeDefender
Laughing Tell someone you love them today because life is short.
Post #139651 16th Apr 2012 8:50pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
Simple answer it's knackered mine did that you could here it at 2000 rpm tell em to change it Thumbs Up
Post #139652 16th Apr 2012 8:51pm
WelshGas
I agree Mick, it probably is, but everything is working well at the moment. But can you, or anyone, explain how or why the EGR valve carries out a cleaning cycle whilst the engine is running. Bow down LANDYWATCH
Post #139665 16th Apr 2012 9:14pm
mick
No idea but mine ran brilliant when the egr was knacked smooth more mpg got the new one fitted and it's not as smooth
Post #139672 16th Apr 2012 9:31pm
Naks
Re: Can any EGR experts advise, please?
It could be that the EGR valve is all gunked up and thus sticking when the revs drop.
Chuck in a bottle of diesel cleaner and see if that clears it up?
If not, regular doses of 2SO should do the trick --
Post #139743 17th Apr 2012 8:59am
WelshGas
Have used 2SO for past 21,000 miles at 250mls/tank. Whistle LANDYWATCH
Post #139857 17th Apr 2012 4:54pm
