Home > Puma (Tdci) > Wading depth
jay knowles
Wading depth
Why is the wading depth only 500mm on the new defender when the air intake is far higher than this, i think i read the discovery is 700mm, thanks Jay
Post #138518 11th Apr 2012 8:17pm
Dave-H
Because LR are covering their ar5e in case you get it wrong .... cant blame a stuffed engine on them .... simples Rolling Eyes Guns and Landrovers .... anything else is irrelevant.
Post #138523 11th Apr 2012 8:29pm
jay knowles
So how much deeper can they safely go. Jay
Post #138526 11th Apr 2012 8:35pm
BigMike
If you have a snorkel then it's really up to you. However, diff breathers are needed, engine, electrics etc. I hate wading and try to avoid it at all costs because of the problems it can create. Never understood the obsession with it (not saying you have that, but just generally when it comes to landrovers)
Oh, and if you have a puma, you cant get a breather on the gearbox without dropping it.
Post #138528 11th Apr 2012 8:38pm
For once Mike I agree with you other than perhaps a ford crossing like Tarr steps. Driving into bomb holes full of water is a sure fire way of ruining a vehicle especially a Puma. With the cost of what could go wrong / damage you'd probably save money by buying an old tdi and using that + it wont have as many electrics.
Post #138544 11th Apr 2012 9:00pm
MK
Not really. You can access the breather from inside by removing the cover. Puma 110" SW
Post #138563 11th Apr 2012 9:38pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Don't think my old tdi has any electrics Mr. Green I get enough water in when it rains without going in a river. 50cm doesnt seem that deep, but maybe it keeps the carpets dry.
The battery is right up the top in a d3 so it might be something to do with that, probably wouldn't be good to immerse the battery.
Dj 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #138611 11th Apr 2012 11:34pm
cradgebank
England 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Richard
Either a 90, 110 or 130.
Discovery 5
Post #138616 12th Apr 2012 1:45am
jst
td5 ecu is under the drivers seat, puma has some electrics under the drivers seat too depending on options/MY. plus breathers as above.
D3/D4 etc have 700mm wading but remember they have air suspension (its lower on coil sprung ones 600mm?) so body work is raised up Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #138624 12th Apr 2012 7:01am
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Don't mean to hijack this thread, but it has reminded me of something I noticed last time I was under the bonnet.
On my MY11, I noticed that on the passengers side (RHD) towards the rear of the inner wing there are three small-bore black plastic pipes poking up which didn't seem to go anywhere, they just ended there clipped together with their tops turned over.
So, I had a quick look underneath with a torch, and they appear to be routed to the front and rear diffs and the third towards the gearbox or transfer case.
So, do they now fit breathers as standard on the Puma?
Pete
Post #138643 12th Apr 2012 8:28am
jst
they always have fitted them as std to all Defenders.
the discussion lies on whether the ones fitted are long enough wade beyond 500mm. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #138651 12th Apr 2012 9:14am
Zagato
It can't do all the electrics any good if you go deeper, especially the alternator but then that must get soaked when driving in rain anyway Rolling Eyes For me it's the muddy silt that does equal harm gets in everywhere, radiator, swivels seals, electrics, chassis all the nooks and crannies and you can never get it all out again Sad
Of course the Defender will do it but I wouldn't put a nice one through that, water grit and mechanicals are not a great combination Sad
Post #138652 12th Apr 2012 9:22am
cradgebank
Pete
Breathers have always been fitted as standard since the introduction of 110 / 90 in 1983/4. Richard
Discovery 5
Post #138653 12th Apr 2012 9:23am
jst
Zagato wrote:
It can't do all the electrics any good if you go deeper, especially the alternator but then that must get soaked when driving in rain anyway Rolling Eyes For me it's the muddy silt that does equal harm gets in everywhere, radiator, swivels seals, electrics, (
starter motors being my biggest nause, esp with an auto Defender! got through 4 s/m one year from wading. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #138654 12th Apr 2012 9:28am
Naks
Just to be safe, re-route your breathers into the engine bay. Doesn't take much effort Thumbs Up --
Post #138659 12th Apr 2012 9:45am
