Home > Maintenance & Modifications > Anyone fitted a La Salle headlining on their own?
RRUK
It's a fairly straightforward job and I'd like to get it done before the Convoy 4 Heroes run on Sunday, but without a spare set of hands I'm not sure if I can do it alone.
Has anyone else done it with a single pair of hands or got any amazing tips on how to hold it up in position while drilling and screwing the damned thing in? Big Cry 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #136293 2nd Apr 2012 4:07pm
Mo Murphy
Grab a friend, you have not got a chance on your own.
HTH
50 Shades of Pennine Grey
Post #136336 2nd Apr 2012 6:16pm
WarPig
Some strategically placed lenghts of timber to prop up the headlining?
Post #136343 2nd Apr 2012 6:47pm
Laurie
The biggest problem in fitting a headlining is keeping it clean.
Post #136344 2nd Apr 2012 7:03pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
I used to have a La Salle headlining - one thing about them is they are solid and completely washable - so not so much of a worry about getting dirty hand prints on them!
Only problem I had with mine was it getting mildewed over winter (condensation!) - but just a damp cloth and a bit of fairy liquid and elbow grease and it was tip-top again!
Post #136346 2nd Apr 2012 7:08pm
richuk
I fitted on in my old DC on my own. That was a 2 piece one. Can't remember too may issues, although I didn't use the supplied plastic fixings. I had some black hex head TEK screws, which I felt held the lining better. I still drilled pilot holes though. It was quite a good fit, but was under tension in a place or two, hence the use of screws. Bits of wood as props would be a good idea though. I think the hardest thing was man handling the thing into the truck in the first place. I glued foam camping mats to the top of mine first in an attempt to insulate it. Used spray contact adhesive for this. Rich
semper in excretia sumus solim profundum variat
Post #136349 2nd Apr 2012 7:31pm
RRUK
Thanks Richuk, mine roof is now fully insulated with aluminium backed sound deadening foam so no worries there.
Mine is in 3 pieces and the supplied fixings are now better, they no longer give you the little fir tree clips but instead the VW T5 style rivet fixings, much better quality. 2016 D4 HSE
Post #136438 3rd Apr 2012 8:03am
