![]() | Home > Maintenance & Modifications > 110 Utility sides -> Series 88? |
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680
hard top backs quite often come up on ebay DEFENDER 90 TDCI XS,
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
If you google LR4x4 and username Pathfinder, he did a conversion on his 110 using series 88" side panels. they fit straight in. A slight tweek of the front edge where the second row door seal goes I think, then all is good.
| Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 |
Series 88" panels are ok, but depending on the age of the 110. If its newer then these panels stand out a mile as they have a raised strip at the front whereas the correct panels are smooth. I bought some 110 hardtop panels and my bodyshop shortened them, re- folding the leading edge for the door seals. Only problem if it bothers you is the internal vertical support is located in different place. This would only affect you if fitting aftermarket interior soundproofing panels from TGE or MUD UK.
| rusty66 Member Since: 22 Jun 2010 Location: Rhineland Posts: 60
Thanks for the answers and sorry for the delay - I've had holidays and a computer problem.
So as the sides are of an 1964 Series 2a and my Defender is MY09 they will stick out? I know that I will have to cut some off to fit the seals, but if they protrude that would look odd, I think. Has anyone ever sources new sides from LR? I guess they charge a fortune? Cheers Boris |
