Home > Puma (Tdci) > Clonk at the rear of my 110
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
Hi,
If this has been discussed already i apologize but searching for +rear +clonk was not returning anything interesting.
So here's the thing: i have a 57 plate 110 Puma. When i move from a standstill i hear a clonk at the rear, then everything is fine. It happens in 1st gear only (apparently)
I am pretty sure it has been discussed already but gcouldn't find clues. As i am due for service i wanted to point the mechanic in the right direction.
Thanks for your precious help
ciao Smile
Post #135090 28th Mar 2012 4:38pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
trailing arm bushes (the front large ones) had this affect for me, I also seem to have started a new clonk, which i now believe is the ball joint on the A frame,
hope this helps
Mark
Post #135182 28th Mar 2012 8:04pm
Zagato
I have a clonk going over speed bumps! Will ask the dealer to check your points Mark Thumbs Up
Post #135189 28th Mar 2012 8:13pm
CyberCharlie
Thanks guys
Post #135437 29th Mar 2012 2:37pm
