Home > Maintenance & Modifications > D44 Fuel Cooler
D44 Fuel Cooler
With the D44 fuel cooler guard what is required to fit I remember that a few nuts have to be undone and be slipped behind the fuel pipes and to be careful not to lose the nut inside the chassis rail. But you don't have to remove any pipe to fit do you? If so that does put me off somewhat. Any help or info would be appriciated. Thumbs Up
Post #131742 15th Mar 2012 10:44pm
bob neville
Easy job.
The nuts in the chassis are captive nuts, you just have to stop them sliding around. No pipes have to be removed to fit, just some gentle moving of the cooler.
Take it slowly and carefully and you will be fine - I was worried when I fitted mine but it was very simple.
2013 Defender 90 CSW - sold
Post #131745 15th Mar 2012 10:55pm
bob neville wrote:
Easy job.
Bob
I'm glad that's the case. It seems a good product from a reliable company. I heard that if the pipes get damaged not only could you be left stranded but they cost a lot too! Just bought a D44 tax disc holder from D44 tonight so might have a look at the cooler guard too one day. Thought £5.81 for delivery of a tax disc was a bit high but then again it is metal and also courier not RM. Thanks for the info once again Bob Thumbs Up Thumbs Up
Post #131752 15th Mar 2012 11:22pm
Post #131755 15th Mar 2012 11:36pm
TJ101
Easy job, as Bob says dont rush it,,
From memory the pipes are £250 odd ??
With the back plate fitted,
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #131756 15th Mar 2012 11:38pm
I will bear that in mind. Thumbs Up Would you mind if I saved your picture TJ for future reference?
Regards
Post #131809 16th Mar 2012 12:20pm
TJ101
Regards
A pleasure,, have a few more somewhere,, but you will not need them California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #132348 18th Mar 2012 6:20pm
