![]() | Home > Td5 > Thermostat change |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8473 ![]() ![]() ![]() |
is there a constant draw of air felt on the front of the vehicle. when a viscous is locked up you can normally feel the draw of air from them. Cheers
jwhat Member Since: 19 Jan 2011 Location: Westmeath Posts: 134 ![]() ![]() ![]() |
I'll check at the weekend when I get back to the 90. Thanks for the tip. Tdci 110 DC |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
Measured it should be 88.2deg c. When sitting idle.
Needle on the gauge sits slightly to the left from Center. This assumes your sender n gauge are correct. What you are getting with the above assumption is around 64deg. The gauge is not linear. The defender has migrated, leaving the owner behind. |
