Home > Puma (Tdci) > Cruise Control for Puma
MartinK
So - I know this has been discussed before, but there does not seem to be an easy/pragmatic upgrade here.
Old thread here: http://www.defender2.net/forum/topic1301.html
TD5's were easy... a few quid off ebay, 20 mins work, and hey-presto.
Anyone managed to find a good solution for Puma yet? I'll be driving the A9 a lot soon and cruise would be a great facility to have...?
Any ideas? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #131573 15th Mar 2012 3:40pm
nakatanenga
Germany
Hi there,
we managed to develop a WORKING cruise control for the Puma.
http://nakatanenga-tours.de/shop/article_T...PDEFTD4%26
Available from the usual suspects in the UK Wink WANTED:
SII or SIII in max 1.5k
Post #131602 15th Mar 2012 5:20pm
TJ101
I have a cruise kit on my Puma, Would be in may top 5 of mods, a pleasure to use every trip Thumbs Up
Looks similar to the kit above, but with a switch panel rather than a stalk
PM Sonic3d and see if he can still get hold of the kits he was doing California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #131694 15th Mar 2012 9:28pm
T1G UP
Re: Cruise Control for Puma
Any ideas?
i will be getting one of these http://www.howard-may.co.uk/ had an email back from them £389.50 self fit delivered or add £145 for fitting at your location.
Post #131714 15th Mar 2012 9:51pm
TJ101
Yep,, that's the same as my kit
Guess they will be fitting yours Marcus Laughing California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #131719 15th Mar 2012 9:59pm
T1G UP
i expect so...shant be drafting Walfy in thats for sure Thumbs Up
Post #131720 15th Mar 2012 10:01pm
TJ101
Joking aside,, A easy fit,,
Main balls you need is curring into the pedal wires etc,,,
Going back to the gearbox for a decent speed pulse,
and using a scan gauge or your Bas box, to reset the engine light, they will come on, when all wired up California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #131726 15th Mar 2012 10:07pm
slick75
Wales 2008 Defender 90 Puma 2.4 HT Stornoway Grey
google conrad anderson he does it had one of his on last car , he does a good job Smile 08 def 90 ht stornaway grey
Post #131747 15th Mar 2012 11:07pm
T1G UP
its on the list...but i want to get the rear finished. I will probably get it fitted as a pro fits always better with an invoice etc Whistle
Post #131751 15th Mar 2012 11:20pm
Zagato
When are you going to put pics up TIG of all your mods Sad
Post #131774 16th Mar 2012 9:18am
nakatanenga
Germany
All others are LITEON brand ECUs and looms. These have to be soldered into the wiring loom at the throttle pedal. This can cause severe problems especialy under wet conditions. Ours is plug&play at the pedal!
As well we found out that these ECUS tend to loose software etc. WANTED:
Post #131800 16th Mar 2012 11:15am
Lorryman100
Peter,
what holds the command stalk onto the trim? And where did you hide the ecu? I like the idea of the piggy back plug over stripping and soldering the OEM wiring. Thumbs Up
Brian.
Post #131835 16th Mar 2012 2:09pm
nakatanenga
Germany
You need to drill a hole into the plastic surround around the steering column. It is boltet securely there.
The ECU hides in the space behind the lodspeakers WANTED:
Post #131851 16th Mar 2012 3:41pm
nakatanenga
Germany
loudspeakers Wink WANTED:
Post #131853 16th Mar 2012 3:43pm
T1G UP
dunno Zag...not done much really.
when your 110 getting out and about?
Post #131912 16th Mar 2012 7:39pm
