![]() | Home > Maintenance & Modifications > XS Carpet Removal |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Hi All
Can't seem to find anything about this in a search (probably being thick) I want to remove some of the carpets in an XS (to fit wiring) and wasn't sure how they are fixed to the floor. Looks like a sort of plastic clip in thing, how is it best to remove these without breaking them (done that before on doors and needed to get new clips ![]() I'm guessing from previous posts that the flat ones in the rear and around seats are double sided tape but the fronts appear to have a proper fixing. Any suggestions please I'd be grateful as I don't want to get it wrong. Ta DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
Cheers Cobs, I had a feeling it would be straightforward, I'll give that try when it's not dark out.
Only need to remove front and first passenger carpet to wire in a subwoofer. Something for the weekend sir I think. Ta Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
The plugs and grommets will probably break. In the front I've removed our carpets since they're just sponges. I've put gaffer/duct tape over the holes in the floor and the rubber mats fit on top. Much less cabin moisture in winter now.
Projectblue Member Since: 22 Nov 2011 Location: Devon Posts: 1098 ![]() ![]() |
Are they the normal trim fit round clips? If so simply buy a trim tool from a tool upply place and you can extract them intact and refit. Works on all trim - e.g. door cards.
