Home > Maintenance & Modifications > Recaro fuse size
ZeDefender
Recaro fuse size
Question for the Leccys here:
Just fitting my new (rather old) Recaro orthopaedic seat with pumps, heating etc. The Puma already has heated seats with a 20A fuse but the Recaro is rated at 30A. How risky is it just to up the fuse to 30A? I could just go straight to the battery with an in-line fuse but would rather use the existing wiring...
Matt Tell someone you love them today because life is short.
Post #130223 10th Mar 2012 12:16am
K9F
Ze,
Via the ignition being switched to on the over all circuit is protected by a 60 amp fuse. The 20 amp fuse is a tap off to provide the supply for the heaters, the circuit also switches in a header earth for the windows. Are the Recaros thermostatically controlled or are they just straight on/off.
If they are thermostatically controlled I would say yes it is ok to just replace the 20 amp with a 30 amp. If not you need to determine the actual current draw of the Recaros.
Current = Voltage divided by resistance.
If you can measure the resistances of the Recaro heater and pump circuits and you can then work it out.
A constant 30 amps in my opinion is too much for the size of 1mm cable I believe is currently fitted. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #130254 10th Mar 2012 9:16am
leeds
Assuming thin wall cabling 1mm2 is 16.5 amps, 2 mm2 is 25 amp and 3 mm2 is 33 amp typically rated.
OK cycle/boost rating will be higher, but if the seats have 30 amp fuse I would be reluctant to run them on 1 mm2 cable.
If you can not easily get cable rating it might be a case of counting number of strands of copper and strand diameter to work out cross sectional area hence cable rating.
Brendan
Post #130270 10th Mar 2012 10:33am
ZeDefender
Cheers guys - thanks for dragging my mind out of coma Thumbs Up
I've just dismantled, re-stitched and "renovated" much of the wiring and air tubing (long night) but no sign of a thermostat Surprised(
They were "made in West Germany", so a looong time ago Shocked Still in good nick though Smile
I will wire them up to a regulated 12V supply, dig out the multimeter, switch on the heating, motors, balloons etc. all at once and measure the current. Will have to allow for the passenger heated seat though...
Really hope this works out - the standard LR seats kill me (even with pads). These are cheap replacements at 200 quid (all nice leather).
Have a good weekend.
Later... Tell someone you love them today because life is short.
Post #130289 10th Mar 2012 1:19pm
