Home > Puma (Tdci) > Help with Part Number
landroverdiver
Hi
Can anyone help please?
I need to replace the Indicator-Horn-Headlamp Dip Switch on my 2007 Puma. I sourced what I thought was the correct part (XPB101290), but it does not fit.
The replacement part has a cranked stalk (mine is straight) and the blue bit that goes over the steering column is a smaller diameter than the current one.
If its relevant it is a 36-spline steering column.
Any help gratefully received.
Mike
Post #128850 5th Mar 2012 2:01pm
duckworthparts
Site Sponsor
what year is your defender https://www.facebook.com/duckworthparts
Send a paypal payment direct using this link www.paypal.me/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: danroberts@duckworthlandrover.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Can also supply OEM & Aftermarket parts
Post #128855 5th Mar 2012 2:15pm
landroverdiver
Post #129058 5th Mar 2012 11:11pm
wslr
Microcat shows 'SWITCH-INDICATOR/HORN/ HEADLAMP DIP' for the Puma models, so that part is correct.
Your part didn't arrive in a blue Britpart bag by any chance??? Confused
Post #129165 6th Mar 2012 2:45pm
duckworthparts
Site Sponsor
yep correct part number for the puma https://www.facebook.com/duckworthparts
Post #129181 6th Mar 2012 4:11pm
landroverdiver
I bought it off ebay from someone who had himself bought the incorrect part. It is in a Britpart box with the part number on the box.
Perhaps all is not as it should be and the box does not contain the correct part!
Its not hugely expensive, I will buy a replacement from a known source.
Many thanks for your assistance.
Mike
Post #129382 7th Mar 2012 9:42am
Martin
Site Admin
Buy genuine or OEM, not a Chinese copy. You'll be buying again before long if you do Sad  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #129383 7th Mar 2012 9:44am
pumaxs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Zambezi Silver
Apologies for resurrecting this old thread, but my recent experience bears out Martin's closing comments.
The original indicator/horn/dipped beam switch suddenly packed up on my Puma back in December 2013.
A quick call to Craddock's established that a genuine replacement would cost £130-ish or a Britpart alternative (XPB101290) would be £19-ish.
Given the reassurance that the Britpart component had a 2year warranty, and the imminence of the Christmas holidays, I took a punt on the cheaper option and got a reliable local garage to fit it.
From the outset, it was clear that the angle of the new switch lever did no suit the Puma dash layout, and fouled it under certain circumstances - i.e. you could not indicate + select main beam at the same time!!
Fast forward to June 2014, and the dipped beam headlamps developed an intermittent fault, and I sometimes had to flick the lever between the dipped + main beam settings to stir them into life.
Very soon afterwards, dipped beam packed up completely & I was left with only side lights or main beam.
My local main dealer diagnosed a faulty relay and duly replaced the part.
However, a day or so later, the intermittent fault reappeared.
A second visit to the main dealers firmly pointed the finger of blame at the Britpart switch & a genuine part replacement was fitted.
Problem solved!!
So, from my personal experience, the moral of this story, is to avoid fitting $hitpart parts as it will probably cost you more in the long run.
Lesson learned!!
I will be taking this matter up with Craddock's, as they were responsible for selling this crap to me. '57 Defender 110 XS Station Wagon 2.4tdci
Post #346951 22nd Jul 2014 12:52pm
