Home > Td5 > snorkel
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
snorkel
will a 300tdi safari snorkel fit a td5?
Post #128724 4th Mar 2012 9:51pm
T1G UP
yes
Post #128728 4th Mar 2012 9:55pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Almost certainly not as the air intake is on the other side of the vehicle!
Post #128729 4th Mar 2012 9:55pm
tolley
is not the 300 the same side Confused and the 200 the other?
Post #128732 4th Mar 2012 9:59pm
T1G UP
yes
Post #128733 4th Mar 2012 10:00pm
markb110
Hi Tolley
You are correct. The 200 TDI has the air intake onthe near side. The 300 and TD5 are the same
Mark
Post #128734 4th Mar 2012 10:01pm
landy andy
Yes Thumbs Up Same one fits
Andy
Post #128737 4th Mar 2012 10:11pm
twopoint6khz
Er, whoops Whistle Embarassed
Carry on
Post #128739 4th Mar 2012 10:13pm
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
I read somewhere a while back that some 300 Tdi RAI/Snorkels (dependant on the make) can be a bit restrictive with airflow for the Td5 and Puma engines so I would just double check that it's suitable for the Td5 before buying.
Post #128740 4th Mar 2012 10:16pm
tolley
i did know that thanks
Post #128741 4th Mar 2012 10:18pm
tolley
looks like its the internal pipes are the only difference.
Post #128884 5th Mar 2012 4:39pm
markb110
Tolley
The original Mantec air metal air intakes were 63mm (outside diameter) but when the TD5 came out they moved to a 70mm (od) pipe based on the requirements from Land Rover. Since then Mantec change all their metal airintakes to that diameter.
Some other makes are still the narrower, should not worry you as you were talking about the Safari version
Mark
Post #128918 5th Mar 2012 7:03pm
tolley
anyone know where i can get pipes for a td5 safari .
Post #130107 9th Mar 2012 5:28pm
