Home > Puma (Tdci) > Landrover Service Actions |
vaucluse Member Since: 04 Feb 2012 Location: SE London Posts: 185 |
Sorry guys, the first code is not T but P ie P022G I've since found out that P019H & P022G were the 1st & 2nd attempt at fixing the parking brake oil leak issue and Q049C was a replacement sump. Still at a loss as to what Q068B was all about? Any ideas? Thanks Mark |
1st Mar 2012 3:43pm |
Simple search under Q068 reveals:- http://www.defender2.net/forum/topic1834.html?highlight=q068 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
1st Mar 2012 5:46pm |
Hi K9F, I did a search but came up with nothing sadly. It is Q068B and not DTC P068 as you suggest. Thanks anyway for looking. Mark |
1st Mar 2012 5:57pm |
Vaucluse revisit the link again as I may have edited it whilst you were looking. I knew Q068 rang a bell with me! It caused me no end of hassle with my remap with incompatability issues some time ago!
Engine Lacks Power and MIL Light On - Service Action Reference: Q068v2_UK (2) Folder: Service Action Bulletins If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
1st Mar 2012 6:02pm |
Thanks buddy - spot on! Much obliged |
1st Mar 2012 6:50pm |
Very welcome! If you go through life with your head in the sand....all people will see is an ar5e!!
1st Mar 2012 7:16pm |
