Home > Maintenance & Modifications > Normal or variable intermittence for the rear wiper
dgardel
Italy
I have post this infos on the "5 best mods made on your Defender" but I think it is better to start a new post.
A. NORMAL INTERMITTENCE FOR THE DEFENDER REAR WIPER(using the OLD front Land Rover relay)
Have you a standard/original Land Rover wiper ECU in your hand?
The green-white cable of position 6 of the base must be put on position 1
B. VARIABLE VOLKSWAGEN INTERMITTENCE FOR THE DEFENDER REAR WIPER
FOR A MORE REFINED SOLUTION, Thank you to BarneyRubble for adding the VW variable timer to the rear wiper
download here the BarneyRubble pdf
Works like the front - press the switch, let it wipe, switch it off, wait until you want it to wipe again, switch it on, and leave it - the wipers operate on intermit at the time you left between switching off and back on again.
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #126166 23rd Feb 2012 5:13pm
Mo Murphy
dgardel, thanks for the post Smile
Ok, scrub that question, I found the answer in the other thread Embarassed The Land Rover 90 - Many are called, few are chosen.
50 Shades of Pennine Grey
Post #126617 25th Feb 2012 12:33pm
HTB
United Kingdom 2012 Defender 90 Puma 2.2 HT Buckingham Blue
Resurrecting an old thread..
i'd like to add this mod to my 2012 Tdci having done the frot wiper years ago, but depsite searching can't find a set of instructions - just the wiring diagram in the link above. Whilst I can probably follow it, I don't want to make too much of a pigs ear of it. Are there any instructions anywhere - the links here are all broken Sad
Thanks,
H
Post #801647 10th Nov 2019 6:17pm
